Hello Umbrel Gurus!
I need your help.
My Raspberry Pi 4 Umbrel crashed (power outage).
I had to reflash (microSD) and reformat SSD. Using umbrelOS 1.4.
I am able to get to the home page with my user id/pwd (I have restarted, rebooted, and even done the factory reset). All wires and internet connections seem to be fine.
But now I am unable to install any apps (I only want to install Bitcoin and Lightning apps).
Here are the logs:
Apr 10 08:34:09 umbrel mender[408]: time=“2025-04-10T08:34:09Z” level=info msg=“Wait 4m0s before next inventory update attempt in 3m59.999944426s”
Apr 10 08:34:15 umbrel umbreld[791]: [apps ] Installing app bitcoin
Apr 10 08:34:16 umbrel umbreld[791]: [apps ] Setting up data directory for bitcoin
Apr 10 08:34:16 umbrel umbreld[2713]: time=“2025-04-10T08:34:16Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
Apr 10 08:34:16 umbrel umbreld[2713]: Container auth Running
Apr 10 08:34:16 umbrel umbreld[2713]: Container tor_proxy Running
Apr 10 08:34:17 umbrel umbreld[2783]: /opt/umbreld/source/modules/apps/legacy-compat/app-script: line 403: /home/umbrel/umbrel/app-data/bitcoin/torrc: Is a directory
Apr 10 08:34:17 umbrel umbreld[791]: [app ] [error] Attempt 1 installing app bitcoin failed. There are 2 retries left.
Apr 10 08:34:18 umbrel umbreld[2840]: /opt/umbreld/source/modules/apps/legacy-compat/app-script: line 403: /home/umbrel/umbrel/app-data/bitcoin/torrc: Is a directory
Apr 10 08:34:18 umbrel umbreld[791]: [app ] [error] Attempt 2 installing app bitcoin failed. There are 1 retries left.
Apr 10 08:34:21 umbrel umbreld[2894]: /opt/umbreld/source/modules/apps/legacy-compat/app-script: line 403: /home/umbrel/umbrel/app-data/bitcoin/torrc: Is a directory
Apr 10 08:34:21 umbrel umbreld[791]: [app ] [error] Attempt 3 installing app bitcoin failed. There are 0 retries left.
Apr 10 08:34:21 umbrel umbreld[791]: [apps ] [error] Failed to install app bitcoin: Command failed with exit code 1: /opt/umbreld/source/modules/apps/legacy-compat/app-script install bitcoin
Apr 10 08:36:02 umbrel systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup of Temporary Directories…
Apr 10 08:36:02 umbrel systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Apr 10 08:36:02 umbrel systemd[1]: Finished systemd-tmpfiles-clean.service - Cleanup of Temporary Directories.
Apr 10 08:36:02 umbrel systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.service.mount: Deactivated successfully.
Apr 10 08:36:10 umbrel umbreld[791]: [server ] [error] jwt malformed
Apr 10 08:36:10 umbrel umbreld[791]: [server ] [error] POST /user.renewToken Invalid token
Apr 10 08:36:41 umbrel umbreld[791]: [apprepository ] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Apr 10 08:36:41 umbrel umbreld[791]: [apprepository ] GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme is already up to date
Apr 10 08:37:12 umbrel umbreld[791]: [umbreld ] [error] Failed to read hidden service for ui: ENOENT: no such file or directory, open ‘/home/umbrel/umbrel/tor/data/web/hostname’
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=info msg=“State transition: inventory-update-retry-wait [Sync] → inventory-update [Sync]”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=info msg=“Device unauthorized; attempting reauthorization”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=error msg=“Failed to authorize with "": failed to build authorization request: failed to obtain authorization message data: failed to obtain identity data: failed to call /usr/share/mender/identity/mender-device-identity: fork/exec /usr/share/mender/identity/mender-device-identity: no such file or directory”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=warning msg=“Reauthorization failed with error: transient error: authorization request failed”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=error msg=“Failed to submit inventory data: transient error: authorization request failed”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=error msg=“inventory submit failed: transient error: authorization request failed”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=warning msg=“Failed to refresh inventory: failed to submit inventory data: inventory submit failed: transient error: authorization request failed”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=info msg=“State transition: inventory-update [Sync] → inventory-update-retry-wait [Sync]”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=info msg=“Handle update inventory retry state try: 8”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=warning msg=“RetryPollIntervalSeconds is not defined”
Apr 10 08:38:09 umbrel mender[408]: time=“2025-04-10T08:38:09Z” level=info msg=“Wait 4m0s before next inventory update attempt in 3m59.999952574s”
Apr 10 08:38:36 umbrel umbreld[791]: [umbreld ] [error] Failed to read hidden service for ui: ENOENT: no such file or directory, open ‘/home/umbrel/umbrel/tor/data/web/hostname’
Please help!
Thank you!
~S
