Rebuilt Umbrel on Rpi4, can't install apps. "no such host" error
Hi team, requesting some help with troubleshooting.
Background:
  • had a power outage while away, and umbrel stopped working. Tried a variety of things but couldn’t get it back up and running, so went the nuclear option of a fresh install, formatted SSD etc.
  • the new install appears to have worked fine, but I can’t install any apps.
Here’s what I’ve tried so far:
  • followed the advice for apps not installing in the troubleshooting guide, using SSH to restart scripts etc
  • Multiple restarts, reflashes of mSD, tried reformatting SSD again etc.
I am a noob, but looking at the debug logs, the obvious looking culprit are lines such as these after starting the install process:
ERROR: for tor Get “https://registry-1.docker.io/v2/getumbrel/tor/manifests/sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a”: Get “https://auth.docker.io/token?scope=repository%3Agetumbrel%2Ftor%3Apull&service=registry.docker.io”: dial tcp: lookup auth.docker.io on [IP address]: no such host
Any advice?
====================== Umbrel debug info ======================Umbrel ve - Pastebin.com
Also tried installing app from SSH rather than GUI, same result.
Hi @ChadLegspin, seems it is pulling with a link to the wrong image.
Let me know how you go after running the following scripts- this updates the repo, as well as the restart scripts you used before
sudo rm ~/umbrel/repos/https—github-com-getumbrel-umbrel-apps-git/.git/index.lock && sudo ~/umbrel/scripts/repo update && sudo ~/umbrel/scripts/stop && sudo ~/umbrel/scripts/start
or
and then try installing bitcoin again
sudo ~/umbrel/scripts/app install bitcoin
For anyone who has this same problem, it was a networking issue. My ISP started using CG-NAT, which means I didn’t have a Public Routable IP address. I got my ISP to sort it, and now things are working again.
