Bitcoin app install is stuck 'Installing'
Trying to install the bitcoin app onto an RPI4. UmbrelOS 0.5.4 ; 2TB SSD connected.
Stuck ‘Installing’ for over 3 hours.
tail ~/umbrel/logs/karen.log
sent 349 bytes  received 18 bytes  734.00 bytes/sec
total size is 14,041  speedup is 38.26
Pulling images for app bitcoin...
Pulling app_proxy   ...
Pulling tor         ...
Pulling i2pd_daemon ...
Pulling bitcoind    ...
Pulling server      ...
Pulling app_proxy   ... error
Pulling tor         ... error
Pulling i2pd_daemon ... error
Pulling server      ... error
Pulling bitcoind    ... error
ERROR: for app_proxy  Get "https://registry-1.docker.io/v2/": dial tcp [2600:1f18:2148:bc00:8d61:9b62:40aa:8bb8]:443: connect: network is unreachable
ERROR: for tor  Get "https://registry-1.docker.io/v2/": dial tcp [2600:1f18:2148:bc02:445d:9ace:d20b:c303]:443: connect: network is unreachable
ERROR: for i2pd_daemon  Get "https://registry-1.docker.io/v2/": dial tcp [2600:1f18:2148:bc01:571f:e759:a87a:2961]:443: connect: network is unreachable
ERROR: for server  Get "https://registry-1.docker.io/v2/": dial tcp [2600:1f18:2148:bc02:445d:9ace:d20b:c303]:443: connect: network is unreachable
Seems to be a problem connecting to registry-1.docker.io
Tried pinging google.com and that works as expected.
Tried reflashing UmbrelOS onto another SD card but same issue.
Any idea how I can install the bitcoin app?
Do you happen to be running the Umbrel behind a VPN?
It should just take a couple minutes to install the app. I would suggest trying the manual install process again.
  2. Type in the following command ssh -t umbrel@umbrel.local and press the Enter key:
    *In the command given above, you can replace umbrel.local with the local IP of your Umbrel if you prefer. If you are using PowerShell on Windows 10, you may need to run ssh umbrel@umbrel instead of the command given above.
  3. Run sudo ~/umbrel/scripts/app install bitcoin
I’m not behind a VPN.
Just installed the previous version of UmbrelOS (0.5.3) and that has installed bitcoin core successfully.
So it appears that something has been introduced in 0.5.4. that my RPI4/network doesn’t like.
I’ll stick with 0.5.3 for now. Thanks for your help.
Hopefully this was resolved for you, but I found in the end the fix for this issue in case anyone else comes by this thread.
    3.In the command given above, you can replace umbrel.local with the local IP of your Umbrel if you prefer. If you are using PowerShell on Windows 10, you may need to run ssh umbrel@umbrel instead of the command given above.
  3. Run sudo systemctl restart docker
