After restoring a broken LND and restoring a channel backup all my channels force closed exept 1.
This channel is stuck on waiting close for 3 days while showing a 0 sats balance.
System: Raspberry Pi 4 4GB, 1TB USB SSD, 1Gbps ethernet.
What to do?
Hi
Did you fix this Problem? And how did you do it?
Because I have the sam Problem as well. I can’t find the transaction in the mempool.
The balance of the channel is shown corectly compared to your problem.
I was lucky I managed to contact my peer because I set up this channel through lightningnetwork.plus. He force closed the channel and after the required amount of blocks funds returned to me. Couldn’t find any other solution. I reached out to several people but nobody seemed to be able to help. I’m sorry that I can’t give you a better answer right now
Ok no problem. But thank you anyway for your feedback.
My problem is that the channel was never get opened. Because also the opening transaction was also never get published on the mempool.
