Karen logs
sending incremental file list
sent 281 bytes received 15 bytes 592.00 bytes/sec
total size is 4,132 speedup is 13.96
Pulling images for app electrs...
Pulling tor ...
Pulling app_proxy ...
Pulling electrs ...
Pulling app ...
Pulling app ... pulling from getumbrel/umbrel-ele...
Pulling app_proxy ... pulling from getumbrel/app-proxy
Pulling tor ... pulling from getumbrel/tor
Pulling app_proxy ... digest: sha256:a2e3e0ddfcf84838bf...
Pulling app_proxy ... status: image is up to date for g...
Pulling app_proxy ... done
Pulling tor ... digest: sha256:2ace83f22501f58857...
Pulling tor ... status: image is up to date for g...
Pulling app ... pulling fs layer
Pulling tor ... done
Pulling app ... waiting
Pulling app ... downloading
Pulling app ... retrying in 5 seconds
Pulling electrs ... error
Pulling app ... retrying in 4 seconds
Pulling app ... retrying in 3 seconds
Pulling app ... retrying in 2 seconds
ERROR: for electrs Get "https://registry-1.docker.io/v2/getumbrel/electrs/manifests/sha256:f215ca7163a3bd42ae3db3563dd2b4600342bc0148641226cb704f8dc8da0b82": dial tcp: lookup registry-1.docker.io on 192.168.1.254:53: no such host
ERROR: for app error pulling image configuration: download failed after attempts=6: dial tcp: lookup auth.docker.io on 192.168.1.254:53: no such host
Got signal: debug
karen is getting triggered!
Does anyone have any input?
Weird that it could pull the proxy, but not the main app.
I’d give the app store a refresh, and try a fresh install again
- Stop Umbrel:
sudo scripts/stop- Reboot your system:
sudo reboot- Start Umbrel:
sudo scripts/start- Uninstall Electrs:
sudo scripts/app uninstall electrs- Install Electrs:
sudo scripts/app install electrs
command not found
Try it like this instead
- cd ~/umbrel
- Stop Umbrel:
sudo reboot- cd ~/umbrel
- Start Umbrel:
