Not installing the new app
I can’t install a new app!!
Sep 05 16:22:25 umbrel umbreld[1966]: [apps         ] [error] Failed to install app mempool: (HTTP code 500) server error - toomanyrequests: You have reached your pull rate limit. You may increase the limit by authenticating and upgrading: https://www.docker.com/increase-rate-limit
Sep 05 16:22:25 umbrel dockerd[474]: time="2024-09-05T16:22:25.957440982Z" level=warning msg="Error getting v2 registry: Get \"https://registry-1.docker.io/v2/\": net/http: request canceled (Client.Timeout exceeded while awaiting headers)"
Sep 05 16:22:25 umbrel dockerd[474]: time="2024-09-05T16:22:25.957598243Z" level=info msg="Attempting next endpoint for pull after error: Get \"https://registry-1.docker.io/v2/\": net/http: request canceled (Client.Timeout exceeded while awaiting headers)"
Sep 05 16:22:25 umbrel dockerd[474]: time="2024-09-05T16:22:25.968764048Z" level=error msg="Handler for POST /images/create returned error: Get \"https://registry-1.docker.io/v2/\": net/http: request canceled (Client.Timeout exceeded while awaiting headers)"
Sep 05 16:22:26 umbrel dockerd[474]: time="2024-09-05T16:22:26.029634259Z" level=error msg="Not continuing with pull after error: toomanyrequests: You have reached your pull rate limit. You may increase the limit by authenticating and upgrading: https://www.docker.com/increase-rate-limit"
