Cant get my umbrel knots node visible on https://bitnodes.io/
Believe I already mapped out from port 8333 to 9333
already checked listening tab in app.
Aswell as other troubleshooting options
end of my wits.
Need help as this is frustrating the hell outa me! @gringoperdido any ideas? I can submit pics
I heard the umbrel isnt listening on ipv4/6…wondering if thats the issue?..static ip? …i need a walkthru from someone who knows more! thanks
  • set Umbrel ip on the router using the Umbrel’s MAC that way you don’t have to worry about static ip in the traditional sense.
  • make sure the port forwarding/trigger is set correctly, 8333 external port and 9333 internal port
Hey..thanks for the advice.
Was able to do that actually.
Still no luck
now trying this
if you have any more ideas lmk!
If you can confirm on your router that Umbrel gets the same IP every time then the only problem is the portforwading part.
how do i confirm same ip?
ssh in and run hostname -I
