Cant access Umbrel.local but can SSH. What can i do next to resolve this?
Hey all. I’m sure you get this question a lot, but I’m not able to access Umbrel.local but i can SSH through Terminal. Is there a function through SSH that I can do to fix this issue?
Hey Sam! Try to get access via the IP address. Otherwise, if you have SSH access, you can reboot with sudo reboot. After that you should have access.
Hi Denny, thanks for the reply. I tried via IP address and that did not work. I just did a reboot via SSH and still cant access it with Brave or Firefox browsers. Any other possible fixes?
Here is what i’m getting from Terminal after reboot. I assume this means i did it correctly.
umbrel@umbrel:~$ sudo reboot
[sudo] password for umbrel:
Broadcast message from root@umbrel on pts/1 (Wed 2024-11-20 20:55:47 UTC):
The system will reboot now!
umbrel@umbrel:~$ Connection to umbrel.local closed by remote host.
You can try to set Static IP:
I dont know if this helps but i ran a debug and here are the results. Good or bad?
0.5.4
Mem: 4.0G 207M 3.4G 1.2M 400M 3.8G
Swap: 4.3G 0B 4.3G
total: 5.2%
system: 5.2%
Memory monitor logs
2024-03-12 06:10:22 Warning memory usage at 92%
2024-03-12 06:11:38 Warning memory usage at 92%
2024-03-12 06:16:43 Warning memory usage at 92%
2024-03-12 06:18:51 Warning memory usage at 92%
2024-03-12 06:20:43 Warning memory usage at 92%
2024-03-12 06:24:23 Warning memory usage at 92%
2024-03-12 06:25:39 Warning memory usage at 92%
2024-03-12 06:26:43 Warning memory usage at 91%
2024-03-12 06:27:48 Warning memory usage at 91%
2024-03-13 12:06:22 Memory monitor running!
overlay 19G 106M 18G 1% /
/dev/sda1 916G 916G 0 100% /home/umbrel/umbrel
Karen logs
Removing bitcoin_bitcoind_1 …
Removing bitcoin_tor_server_1 …
Removing bitcoin_app_proxy_1 …
Removing bitcoin_tor_1 …
Removing bitcoin_i2pd_daemon_1 …
Removing bitcoin_bitcoind_1 … done
Removing bitcoin_i2pd_daemon_1 … done
Removing bitcoin_app_proxy_1 … done
Removing bitcoin_server_1 … done
Removing bitcoin_tor_1 … done
Removing bitcoin_tor_server_1 … done
Going to remove bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_tor_server_1, bitcoin_app_proxy_1, bitcoin_tor_1, bitcoin_i2pd_daemon_1
Stopping bitfeed_api_1 … done
Removing bitfeed_web_1 …
Removing bitfeed_app_proxy_1 …
Removing bitfeed_tor_server_1 …
Removing bitfeed_api_1 …
Removing bitfeed_api_1 … done
Removing bitfeed_web_1 … done
Removing bitfeed_app_proxy_1 … done
Removing bitfeed_tor_server_1 … done
Going to remove bitfeed_web_1, bitfeed_app_proxy_1, bitfeed_tor_server_1, bitfeed_api_1
Stopping Docker services…
Stopping nginx …
Stopping tor_proxy …
Stopping auth …
Stopping tor_server …
Stopping manager …
Stopping dashboard …
Stopping tor_server … done
Stopping nginx … done
Stopping tor_proxy … done
Stopping auth … done
Stopping dashboard … done
Stopping manager … done
Removing nginx …
Removing tor_proxy …
Removing auth …
Removing tor_server …
Removing manager …
Removing dashboard …
Removing dashboard … done
Removing nginx … done
Removing tor_server … done
Removing tor_proxy … done
Removing auth … done
Removing manager … done
Docker containers
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/v1.44/containers/json”: dial unix /var/run/docker.sock: connect: permission denied
Umbrel logs
/home/umbrel/umbrel/scripts/debug: line 131: docker-compose: command not found
Tor Proxy logs
/home/umbrel/umbrel/scripts/debug: line 137: docker-compose: command not found
This script requires “docker-compose” to be installed
==== Result ====
I’m on a Mac and i’m totally struggling on how to set Static IP
Ok i think i was able to set Static IP but still cant login. Anyone else have any suggestions?
Try ~/umbrel/scripts/stop && sudo reboot. You could also try a different browser.
I figured out the issue. My external HD was full. Don’t know how that happened since its a 2TB hard drive. I had to delete everything off it and start fresh. I’m back in business.
Thank you again for your help.
I’m glad you were able to resolve the issue. :muscle:
I just wanted to add that if you can’t get to your node by navigating to “umbrel.local” in your browser, sometimes clearing your browser data will fix that.
