I had not logged into my node for quite sometime and when I tried recently it failed to find my local. After a few tries I realized that it was on my Other Wifi and I then logged in no problem. This brings up the question if the Wifi I have it on goes down how can I log into it and or find it.
Strongly recommend to connect your node with a cable to the router and set a static IP for the node.
And on the other side… connect your computer via ethernet cable too in case Wifi goes down! Easier and faster
Umbrel Modem PC
Okay got it, simple enough. Thanks
LOL nice drawing !
