My Umbrel node is offline. I can’t make it work. When I open Bitcoin/Lightning Node it looks like this (see image at bottom).
I got this problem before and after updating to Umbrel 0.5.3
I run on a Intel NUC. (not a Pi)
Umbrel &
Bitcoin log:
https://pastebin.com/kdcJJx8C
I tried to do the following:
/opt/umbrel/scripts/app stop
and then
/opt/umbrel/scripts/app start
This did not fix the problem.
When I execute
/opt/umbrel/scripts/app compose lightning exec lnd lncli unlock
Then I get this after entering moneyprintergobrrr:
https://pastebin.com/u7TpmmR3
I also deleted lnd.config.
I also deleted all my apps after this post (except Bitcoin and lightning) this did not fix the problem.
I did ask help on the Umbrel Telegram and in a Dutch Lightning community, but so far nobody could help me with the correct fix.
I really don’t know how to fix and what to do next.
Help will be much appreciated.
Thank you in advance ![]()
Bitcoin and Lightning do not load when I open it.
