My Umbrel node is offline. I can’t make it work. When I open Bitcoin Node it looks like this. My apps pop up as normal.
I got this problem before and after updating to Umbrel 0.5.3
I run on a Intel NUC. (not a Pi)
Umbrel log:
https://pastebin.com/iKZ158UQ
Bitcoin log:
I will drop this in the comments! (can’t upload more than 2 links as a new user)
I tried to do the following:
/opt/umbrel/scripts/app stop
and then
/opt/umbrel/scripts/app start
This did not fix the problem.
When I execute
/opt/umbrel/scripts/app compose lightning exec lnd lncli unlock
Then I get this after entering moneyprintergobrrr:
https://pastebin.com/u7TpmmR3
I really don’t know how to fix and what to do next.
Help will be much appreciated.
Thank you in advance ![]()
