Per the title, my node is synced and elect rs is synced but i cannot get electrum to connect to the node. I tried umbrel.local, the ip address of the raspi and the tor address provided. None of them work to connect to electrum.
My last node i just used the IP address od the node my router assigned it and i had zero connection issues.
Any help is appreciated thanks!
do you mind to paste a screenshot of your Electrum app’s Private Electrum tab to show the settings you’ve inputted to help troubleshoot?
Electrum Wallet desktop or Andoid? Did you take a look at the guides?
You can use either Tor or Tailscale just remember to add :50001:t at the end of your node’s IP/torURL.
Thank youuuuu!
Adding the ‘t’ made the trick!
Electrum automatically added an ‘s’
What are those?
