I did just that… no connection here.
In step 6 electrum version 4.2.2 gives the option to “use Tor proxy 9150”. I’ve tried both options and it doesn’t work.
The Tor address that you’re putting into the Electrum settings, where do you get this Tor address from? Umbrel settings or the Connect button in the Bitcoin “app”?
This should be updated. I believe the appropriate way to connect is to download ELECTRS from the Umbrel App store, wait for the app to finish syncing to 100% and then slide the connection parameters to TOR. User should download TOR browser, open it and minimize it after the browser has finished making its connections. Open Electrum and click on the circle and enter the Onion address from ELECTRS with :50001:t at the end of the address. Make sure Proxy is clicked on (“Use Tor proxy at port 9150”; the second box will be automatically clicked on (“Use Proxy” with SOCKS5, 127.0.0.1, 9150)). Hit close and Electrum blue button should be BLUE. Success. TOR browser has to be open first when using Electrum Wallet this way to verify transactions.
Has anyone managed to connect Electrum via Tor? I enter the addresses provided to me in the Bitcoin and Electrs apps, but in neither case does my wallet connect. How to fix it?
I am getting complete ZERO here. My Ubuntu says it has no more disc space left, so I closed it down. I tried syncing my Electrum wallet with the Bitcoin node via TOR proxy (changed to port 9150 and still nothing. I think Umbrel sucks, if I may say so! I want my own node on my PC with Electrum syncing with it as Sparrow doesn’t sync either, nor Spectre. I have a full bitcoin core node up to date but still no joy = nothing happens apart from looking at it and seeing how many blocks are on the blockchain and the 10 peers, etc. No transmission of anything.
I completely understand you! I spent about $315 to buy a Raspberry pi 4 and set up my own bitcoin node to verify my transactions without third party trust, but I just can’t use it! I’m seriously considering selling it all. Keeping a full node for greater decentralization of the network is certainly good, but what if I can’t ensure the security of my own transactions? I’m thinking about switching to Citadel node, maybe everything will work fine there.
Thanks for your reply and apologies for the late reply as I can’t log in to Umbrel anymore for lack of disc space. I remember reading the name Citadel but I don’t know it. However the best from my desperate researches is Embassy from Start9. https://start9.com/ The real best is this Pro version https://store.start9.com/collections/embassy/products/embassy-pro but you can buy the normal one for a third of that price and get a discount by paying in Bitcoin.
I think Umbrel sucks. I had to install Ubuntu to get into Umbrel and then erased Windows 10 out of a Dual PC from HP Pavillion 23 and now i am stuck as the partitions I made don’t allow me to reinstall Windows. What a waste of energy!
Bye for now.
Diogo: Que é feito? Fiquei sem Umbrel e sem espaço nas partições do Ubuntu, Grabde Cáca, esta avenida. Vou comprar o Embassy da Start9. O meu Node está OK updated mas não sei se consiguirei sincrnizar com a Sparrow, contudo pelo Electru a Sparrow sincroniza só que n
ao é totalmente privado.
hello! I see… maybe your hardware had somekind of problem…from what I heard embassy its solid
but you had your ubuntu on which system? just curiosity…
idk about sparrow…
These steps still are working, you can update Electrum current version is 4.4.3 and on Umbrel Electrs app is on 0.9.10 as of this post.
To clear up any confusion from earlier posts, you should follow step 1 so your device running Electrum Desktop Wallet can use the Tor network first. You don’t need to be using a Tor browser- you can simply navigate to your Umbrel dashboard via any browser you prefer > Click Electrs app > copy the credential listed under address on the Tor tab within the Electrs application:
After that is installed you can follow all the other steps, plugging in proxy port 9050 does work - so does replacing 127.0.0.1 and keeping localhost in that field - either way can work.
Server should end in: .onion:50001:t
When you’re on the Network screen you can hit enter after entering details, if after a few seconds you still see the red dot, try just relaunching Electrum Desktop once and it should connect immediately.
Let me know if you have any questions or if anything can be more clear, thank you!
