matze
May 1, 2021, 8:06pm
1
Hi there,
everything ran super smooth for approx. 2 weeks, somehow I can’t access the umbrel dashboard anymore - not via “http:umbrel.local” or via the IP address. However I can access via SSH and I also updated manually to 0.3.9 - this is the setup (all recommended hardware, also official power supply …) :
Debug logs: https://umbrel-paste.vercel.app/688667b5-778c-4866-b68e-835e176f590d
Would love to find a solution here, tried to:
reboot via ssh -t umbrel@umbrel.local “sudo reboot” --> no luck
added umbrel to hosts (Mac) --> no luck
tried different devices in the same network --> no luck
I am pretty much out of ideas, appreciate any help - Cheers!
matze
May 2, 2021, 9:50am
4
aarondewes:
sudo systemctl status umbrel-external-storage-sdcard-update.service
Ok! This seems like it’s the issue:
umbrel-external-storage-sdcard-update.service - External Storage SDcard Update
Loaded: loaded (/etc/systemd/system/umbrel-external-storage-sdcard-update.ser
Active: failed (Result: exit-code) since Sat 2021-05-01 20:01:39 UTC; 13h ago
Process: 966 ExecStart=/home/umbrel/umbrel/scripts/umbrel-os/external-storage/
Main PID: 966 (code=exited, status=2)
May 01 20:01:39 umbrel external storage updater[966]: Yes, it does, attempting a
May 01 20:01:39 umbrel external storage updater[966]: ==========================
May 01 20:01:39 umbrel external storage updater[966]: =============== UPDATE ===
May 01 20:01:39 umbrel external storage updater[966]: ========== Stage: Download
May 01 20:01:39 umbrel external storage updater[966]: An update is already in pr
May 01 20:01:39 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service
May 01 20:01:39 umbrel systemd[1]: Failed to start External Storage SDcard Updat
lines 1-16/16 (END)
What do you suggest I do? I already flashed the SDcard once with the newest update 0.3.9, should I do it again?
I tried to update via SSH before I flashed the SDcard, did I brake the update progress via the flash maybe?
matze
May 2, 2021, 11:59am
6
aaand I am back
So what was the issue? The update was stuck and I had to stop it + reboot?
Cheers and thank you @aarondewes
I just installed it yesterday and everything was fine until it wasn’t and now I can’t access the dashboard as well, either through IP or Umbrel.local but can SSH.
Umbrel was already on the latest version so I don’t think it would be an update issue.
Here is the log: https://umbrel-paste.vercel.app/4108d7d1-d925-43fc-941e-a79238d55299
Thank in advance for any help!
