Cannot access umbrel.local and node seems frozen
I cannot access umbrel.local. I have my VPN turned off and have tried multiple versions of the URL. Although I cannot access the app to confirm, my node appears to be frozen, as the screen is stuck on a BTC price from a week ago. What can I do? Many troubleshooting discussions says to reset the node via the Settings menu, but I cannot access it without accessing umbrel.local. Thank you.
I am having same issue.
Hey, have you tried to connect via ssh and restart your umbrel from the terminal?
Thanks very much for this suggestion. I did try that, but was unable to connect via SSH. I ended up just unplugging the power. Was then able to access the Settings and do a software reboot. Am now 100% synced. Thanks again for the help.
