Hello,
I tried reading all the other threads on this topic and couldn’t find a solution that worked.
My BTC node was first stuck in “starting,” now when I try to select the Bitcoin node app in my Umbrel dashboard it leads to a broken page that says:
This site can’t be reached
http://umbrel.local:2100/ is unreachable.
ERR_ADDRESS_UNREACHABLE
The problem began when I moved back in June and didn’t shut down the node properly - just unplugged it and tried to start it back up later.
I tried to SSH in and enact solutions described elsewhere but nothing worked. In most cases, I kept getting a message saying “no such file or directory.” I also saw something in the debug logs about the node being vulnerable, bad warning messages saying the node could be hacked or something. I’m going to shut Umbrel down for now until I can fix everything.
I’ve put the debug logs in a Google doc since I wasn’t able to download them: BTC node logs - Google Docs
Any help would be much appreciated.
(I’m on an M3 Macbook Air, btw.)
