I can connect via the ip address or umbrel.local. Once the login screen loads in takes my correct password, but then gives an error message at the bottom right hand side of the screen that says “app is missing” and won’t go any further… id just start over but I have some BTC on the node and would rather not lose it. Any help is apreciated.
this is running on a raspberry pi4.
