Installed BTCPay from the app store and btcpay-server_web_1 wont start but all other containers start. I ran docker logs --tail 1000 btcpay-server_web_1 and got this.
info: Configuration: Data Directory: /data
info: Configuration: Configuration File: /data/Main/settings.config
info: Configuration: Creating configuration file
info: BTCPayServer.Plugins.PluginManager: Loading plugins from /data/plugins
info: BTCPayServer.Plugins.PluginManager: Adding and executing plugin BTCPayServer - 1.6.12.0
info: BTCPayServer.Plugins.PluginManager: Adding and executing plugin BTCPayServer.Plugins.Shopify - 1.6.12.0
info: BTCPayServer.Plugins.PluginManager: Adding and executing plugin BTCPayServer.Plugins.Crowdfund - 1.6.12.0
info: BTCPayServer.Plugins.PluginManager: Adding and executing plugin BTCPayServer.Plugins.PayButton - 1.6.12.0
info: BTCPayServer.Plugins.PluginManager: Adding and executing plugin BTCPayServer.Plugins.PointOfSale - 1.6.12.0
info: Configuration: Supported chains: BTC
info: Configuration: BTC: Explorer url is http://10.21.21.20:32838/
info: Configuration: BTC: Cookie file is /data/.nbxplorer/Main/.cookie
info: Configuration: Network: Mainnet
fail: BTCPayServer.Hosting.MigrationStartupTask: Error on the MigrationStartupTask
Npgsql.NpgsqlException (0x80004005): Failed to connect to 10.21.21.21:5432
—> System.Net.Sockets.SocketException (111): Connection refused
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token)
at System.Net.Sockets.Socket.g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken)
at Npgsql.TaskExtensions.ExecuteWithTimeout(Func2 func, NpgsqlTimeout timeout, CancellationToken cancellationToken) at Npgsql.Internal.NpgsqlConnector.ConnectAsync(NpgsqlTimeout timeout, CancellationToken cancellationToken) at Npgsql.Internal.NpgsqlConnector.ConnectAsync(NpgsqlTimeout timeout, CancellationToken cancellationToken) at Npgsql.Internal.NpgsqlConnector.RawOpen(SslMode sslMode, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken, Boolean isFirstAttempt) at Npgsql.Internal.NpgsqlConnector.<Open>g__OpenCore|195_1(NpgsqlConnector conn, SslMode sslMode, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken, Boolean isFirstAttempt) at Npgsql.Internal.NpgsqlConnector.Open(NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken) at Npgsql.UnpooledConnectorSource.Get(NpgsqlConnection conn, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlConnection.<Open>g__OpenAsync|45_0(Boolean async, CancellationToken cancellationToken) at Microsoft.EntityFrameworkCore.Storage.RelationalConnection.OpenInternalAsync(Boolean errorsExpected, CancellationToken cancellationToken) at Microsoft.EntityFrameworkCore.Storage.RelationalConnection.OpenInternalAsync(Boolean errorsExpected, CancellationToken cancellationToken) at Microsoft.EntityFrameworkCore.Storage.RelationalConnection.OpenAsync(CancellationToken cancellationToken, Boolean errorsExpected) at Npgsql.EntityFrameworkCore.PostgreSQL.Storage.Internal.NpgsqlDatabaseCreator.Exists(Boolean async, CancellationToken cancellationToken) at Npgsql.EntityFrameworkCore.PostgreSQL.Storage.Internal.NpgsqlDatabaseCreator.Exists(Boolean async, CancellationToken cancellationToken) at Microsoft.EntityFrameworkCore.Migrations.HistoryRepository.ExistsAsync(CancellationToken cancellationToken) at Microsoft.EntityFrameworkCore.Migrations.Internal.Migrator.MigrateAsync(String targetMigration, CancellationToken cancellationToken) at BTCPayServer.Hosting.MigrationStartupTask.Migrate(CancellationToken cancellationToken) in /source/BTCPayServer/Hosting/MigrationStartupTask.cs:line 608 at BTCPayServer.Hosting.MigrationStartupTask.ExecuteAsync(CancellationToken cancellationToken) in /source/BTCPayServer/Hosting/MigrationStartupTask.cs:line 85 Unhandled exception. Npgsql.NpgsqlException (0x80004005): Failed to connect to 10.21.21.21:5432 ---> System.Net.Sockets.SocketException (111): Connection refused at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at Npgsql.TaskExtensions.ExecuteWithTimeout(Func2 func, NpgsqlTimeout timeout, CancellationToken cancellationToken)
at Npgsql.Internal.NpgsqlConnector.g__OpenCore|195_1(NpgsqlConnector conn, SslMode sslMode, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken, Boolean isFirstAttempt)
at Npgsql.NpgsqlConnection.g__OpenAsync|45_0(Boolean async, CancellationToken cancellationToken)
at Microsoft.AspNetCore.Hosting.WebHostExtensions.StartWithTasksAsync(IWebHost webHost, CancellationToken cancellationToken) in /source/BTCPayServer/Extensions/WebHostExtensions.cs:line 19
at BTCPayServer.Program.Main(String[] args) in /source/BTCPayServer/Program.cs:line 70
info: Configuration: Root Path: /
fail: Configuration: Error while trying to connection to explorer.postgres: 3D000: database “nbxplorermainnet” does not exist
info: PayServer: DelayedTransactionBroadcasterHostedService successfully exited…
info: PayServer: TorServices successfully exited…
info: PayServer: CheckConfigurationHostedService successfully exited…
info: PayServer: PullPaymentHostedService successfully exited…
info: BTCPayServer.Payments.Lightning.LightningPendingPayoutListener: LightningPendingPayoutListener successfully exited…
info: PayServer: RatesHostedService successfully exited…
info: PayServer: DynamicDnsHostedService successfully exited…
info: PayServer: NewVersionCheckerHostedService successfully exited…
info: PayServer: DbMigrationsHostedService successfully exited…
