BTCPay server Connection refused (10.21.21.20:32838)
Hey again,
I have installed BTCPay server on my Umbrel pi node and I am getting this message and error in a BTCPay server popup, even though my bitcoin node is 100% synchronized:
Your nodes are synching…
Your node is synching the entire blockchain and validating the consensus rules…
BTC
  • The node is offline
  • Last error: Connection refused (10.21.21.20:32838)
Any idea why I am still getting this message? I installed BTCPay server last week, and have had the message since. I installed BTCPay server after I had already synchronized the bitcoin blockchain, so it was synced from the start.
Where can I go online to get some support for this? I want to chat or use a forum or something where you get feedback.
Is it possible for someone to explain what the number in this error is?
Where is BTCPay getting this number?
Is it an IP address and port?
How can I edit this?
Is this something to do with my Bitcoin node?
I have removed BTCPay from the node, rebooted the node, and added BTCPay again, and I still have the exact same error.
In my Umbrel logs I see this for BTCPay server:
btcpay-server
web_1 | fail: PayServer: BTC: NBXplorer error Connection refused (10.21.21.20:32838)
This line is repeated over and over.
Hi, have you figured this out? I’ve just started getting this " Your nodes are synching … " and the error as well, although it is slightly different
> Last error: Connection refused (btcpay-server_nbxplorer_1:32838)
I assume the difference will be due to the newer version of Umbrel I am running now (May 2023).
Thanks for anyone’s help!
