BlueWallet not connecting to Umbrel
My BlueWallet on my phone is failing to connect to my Umbrel. My node is 100% synced and all my other wallets on my laptop connect to it. Any ideas why this issue popped up all of a sudden? Was working fine yesterday. Even tried deleting the node info out of BlueWallet and reconnecting, but still nothing. Any ideas what the issue could be?
Tor. Is nothing wrong with your node or BW app.
Is just Tor that sometimes is not working.
Try using BW + orbot (not the integrated Tor in BW)
I was thinking that might be the case. I’m on iOS so no other way to access tor there far as I’m aware.
We are in 2021 and I still do not understand why people still use that useless iShit?
Get a damn decent android phone and throw away that dumb ishit.
Just did a restart on my Umbrel and now Sparrow and Blue are connecting again as normal. Good to go. So, if anyone’s Umbrel is running fine/synced but wallets aren’t connecting, there’s an option to try.
i got same probleme here …
i tryied samourai , page open on 192.168.0.10
page appear ,i got the how to , i folow it
but the QR code dont appear = unusable here …
i install blue wallet from umbrel , i start it ,
http://192.168.0.10:3004/ unaccessible …
reboot ,umbrel , restart : unaccessible ,
uninstall , reboot ,install : unaccessible …
i install blue wallet on android , i folow how to
… ligthing network , import , scan QR code : NOT FOUND error
im just 100% synchro , but i cant add wallet …
idk what to do now …
waiting for fixed version of umbrel …
or i have to try older version …
Are you running the most current version? Also, have you tried the “Restart” option on the settings page to reboot it? I would make sure to use the most updated version of everything, wallets included, and try a restart on the node.
In this guide, I explained step by step how to connect a BW mobile app to Umbrel node. There are 2 ways and I see that people still don’t get it.
actually on umbrel i got this “bug” :
i try to install blue wallet and lighting manager from app store
i have installing ,lighing dark/clear ,long time after
change to starting ,ligting dark & clear ,
on my chrome new page open : connection refused …
same for ligthing manager , i start it
new page open from umbrel ip : connection refused …
actually ,im missing the QR code from blue wallet on umbrel …
i have to scan QR code to add on wallet on my android blue wallet …
Thanks I had the same issue. I didn’t know Orbot would help.
