BlueWallet Desktop
I’m trying to connect my BlueWallet desktop app, but when I scanned the QR for the Umbrel server, BlueWallet said Alert: Tor connections are not supported.
I was able to connect successfully using my phone, so I assume this is a limitation of the desktop app. Has anyone found a workaround for this?
If you’re using the latest version of BlueWallet desktop, then it is not possible to connect to your Umbrel via Tor. You’d need to wait for the BW team to implement it on desktop.
