Hi guys, this is the last time I will try to fix the shitty umbrel node. If nobody can help, I will switch to RaspiBlitz.
/dev/root 29G 4.7G 24G 17% /
/dev/sda1 916G 588G 282G 68% /home/umbrel/umbrel
Startup service logs
-- Logs begin at Tue 2023-12-19 16:36:29 UTC, end at Wed 2023-12-20 13:49:40 UTC. --
-- No entries --
External storage service logs
-- No entries --
-- No entries --
Karen logs
karen is getting triggered!
Got signal:
Got signal: debug
Debug result file generated
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
3415 bytes (3.4 kB, 3.3 KiB) copied, 0.00045457 s, 7.5 MB/s
Creating encrypted tarball...
backup/
backup/.padding
backup/channel.backup
Uploading backup...
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
100 6110 0 0 100 6110 0 2868 0:00:02 0:00:02 --:--:-- 2868
100 6256 100 146 100 6110 56 2365 0:00:02 0:00:02 --:--:-- 2421
{"message":"Successfully uploaded backup 1703021704676.tar.gz.pgp for backup ID 18f813c9b82a56b0170a796e758c3dd9edd7a8fe5711a8d7657a5fc5467f6c10"}
====== Backup success =======
Got signal: backup
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
553 bytes copied, 0.000445792 s, 1.2 MB/s
backup/
backup/.padding
Uploading backup...
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
100 3398 100 146 100 3252 28 640 0:00:05 0:00:05 --:--:-- 669
100 3398 100 146 100 3252 28 640 0:00:05 0:00:05 --:--:-- 668
{"message":"Successfully uploaded backup 1703062543452.tar.gz.pgp for backup ID 18f813c9b82a56b0170a796e758c3dd9edd7a8fe5711a8d7657a5fc5467f6c10"}
Got signal: debug
Docker containers
NAMES STATUS
electrs_app_1 Up 24 hours
electrs_electrs_1 Up 2 seconds
electrs_app_proxy_1 Up 24 hours
electrs_tor_1 Up 24 hours
electrs_tor_server_1 Up 24 hours
bitcoin_server_1 Up 24 hours
bitcoin_bitcoind_1 Up 1 second
bitcoin_i2pd_daemon_1 Up 24 hours
bitcoin_tor_server_1 Up 24 hours
bitcoin_tor_1 Up 24 hours
bitcoin_app_proxy_1 Up 24 hours
bluewallet_lndhub_1 Restarting (4) 41 seconds ago
bluewallet_app_proxy_1 Up 24 hours
bluewallet_redis_1 Up 24 hours
bluewallet_tor_server_1 Up 24 hours
btcpay-server_web_1 Up 24 hours
btcpay-server_nbxplorer_1 Up 24 hours
btcpay-server_app_proxy_1 Up 24 hours
btcpay-server_tor_server_1 Up 24 hours
btcpay-server_postgres_1 Up 24 hours
lightning_tor_server_1 Up 24 hours
lightning_lnd_1 Up 6 hours
lightning_app_proxy_1 Up 24 hours
lightning_tor_1 Up 24 hours
lightning_app_1 Up 24 hours
snowflake_web_1 Up 24 hours
snowflake_proxy_1 Up 24 hours
snowflake_tor_server_1 Up 24 hours
snowflake_app_proxy_1 Up 24 hours
lightning-shell_web_1 Up 24 hours
lightning-shell_tor_server_1 Up 24 hours
lightning-shell_app_proxy_1 Up 24 hours
nginx Up 24 hours
manager Up 24 hours
dashboard Up 24 hours
auth Up 24 hours
tor_server Up 24 hours
tor_proxy Up 24 hours
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.0.23 - - [Wed, 20 Dec 2023 13:49:37 GMT] "GET /v1/account/token?token=8ee5765e71e908259a23e6bf95767f49b7e73a3ce25b6f20778e3a4c23d6fddf HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:37 GMT] "GET /v1/system/storage HTTP/1.0" 200 1054 "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:38 GMT] "GET /v1/apps HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:38 GMT] "GET /v1/system/is-sd-card-failing HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:38 GMT] "GET /v1/system/get-update HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:40 GMT] "GET /v1/system/temperature HTTP/1.0" 200 2 "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:40 GMT] "GET /v1/system/info HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:40 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:40 GMT] "GET /v1/system/update-status HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 20 Dec 2023 13:49:42 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Dec 19 22:34:09.000 [warn] Received http status code 404 ("Not found") from server 65.21.94.13:8443 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566+EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy | Dec 20 00:17:10.000 [warn] Received http status code 404 ("Not found") from server 65.21.94.13:8443 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566+EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_proxy | Dec 20 01:55:04.000 [notice] Heartbeat: Tor's uptime is 12:00 hours, with 0 circuits open. I've sent 1.46 MB and received 14.23 MB. I've received 12 connections on IPv4 and 0 on IPv6. I've made 13 connections with IPv4 and 0 with IPv6.
tor_proxy | Dec 20 01:55:04.000 [notice] While bootstrapping, fetched this many bytes: 700409 (consensus network-status fetch); 14104 (authority cert fetch); 12616843 (microdescriptor fetch)
tor_proxy | Dec 20 01:55:04.000 [notice] While not bootstrapping, fetched this many bytes: 79046 (consensus network-status fetch); 9981 (authority cert fetch); 57897 (microdescriptor fetch)
tor_proxy | Dec 20 07:55:04.000 [notice] Heartbeat: Tor's uptime is 18:00 hours, with 0 circuits open. I've sent 1.47 MB and received 14.33 MB. I've received 12 connections on IPv4 and 0 on IPv6. I've made 17 connections with IPv4 and 0 with IPv6.
tor_proxy | Dec 20 07:55:04.000 [notice] While bootstrapping, fetched this many bytes: 700409 (consensus network-status fetch); 14104 (authority cert fetch); 12616843 (microdescriptor fetch)
tor_proxy | Dec 20 07:55:04.000 [notice] While not bootstrapping, fetched this many bytes: 132959 (consensus network-status fetch); 23031 (authority cert fetch); 57897 (microdescriptor fetch)
tor_proxy | Dec 20 08:55:57.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 125 buildtimes.
tor_proxy | Dec 20 11:03:12.000 [warn] Received http status code 404 ("Not found") from server 65.21.94.13:8443 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566+EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_tor_server_1, bitcoin_tor_1, bitcoin_app_proxy_1
app_proxy_1 | Validating token: 8ee5765e71e9 ...
bitcoind_1 | 2023-12-20T13:49:41Z * Using 53.4 MiB for transaction index database
bitcoind_1 | 2023-12-20T13:49:41Z * Using 46.7 MiB for basic block filter index database
bitcoind_1 | 2023-12-20T13:49:41Z * Using 8.0 MiB for chain state database
bitcoind_1 | 2023-12-20T13:49:41Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
bitcoind_1 | 2023-12-20T13:49:41Z init message: Loading block index…
bitcoind_1 | 2023-12-20T13:49:41Z Assuming ancestors of block 000000000000000000035c3f0d31e71a5ee24c5aaf3354689f65bd7b07dee632 have valid signatures.
bitcoind_1 | 2023-12-20T13:49:41Z Setting nMinimumChainWork=000000000000000000000000000000000000000044a50fe819c39ad624021859
bitcoind_1 | 2023-12-20T13:49:41Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoind_1 | 2023-12-20T13:49:41Z Opened LevelDB successfully
bitcoind_1 | 2023-12-20T13:49:41Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
tor_1 | Dec 20 08:00:49.000 [notice] Heartbeat: Tor's uptime is 18:00 hours, with 23 circuits open. I've sent 27.78 MB and received 84.60 MB. I've received 121 connections on IPv4 and 0 on IPv6. I've made 99 connections with IPv4 and 0 with IPv6.
tor_1 | Dec 20 08:00:49.000 [notice] While bootstrapping, fetched this many bytes: 700387 (consensus network-status fetch); 14104 (authority cert fetch); 12607472 (microdescriptor fetch)
tor_1 | Dec 20 08:00:49.000 [notice] While not bootstrapping, fetched this many bytes: 144206 (consensus network-status fetch); 32760 (authority cert fetch); 204008 (microdescriptor fetch)
tor_1 | Dec 20 08:00:49.000 [notice] Average packaged cell fullness: 74.568%. TLS write overhead: 2%
tor_1 | Dec 20 08:55:04.000 [warn] Received http status code 404 ("Not found") from server 82.165.215.69:443 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566+EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Dec 20 08:56:08.000 [notice] No circuits are opened. Relaxed timeout for circuit 1945 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 4860 seconds]
tor_1 | Dec 20 10:45:05.000 [warn] Received http status code 404 ("Not found") from server 82.165.215.69:443 while fetching "/tor/keys/fp/D586D18309DED4CD6D57C18FDB97EFA96D330566+EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97".
tor_1 | Dec 20 10:59:26.000 [notice] No circuits are opened. Relaxed timeout for circuit 2102 (a Hidden service: Establishing introduction point 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 7440 seconds]
tor_1 | Dec 20 12:34:46.000 [notice] No circuits are opened. Relaxed timeout for circuit 2248 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [3 similar message(s) suppressed in last 5760 seconds]
i2pd_daemon_1 | 13:20:26@912/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 13:21:54@254/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 13:24:27@26/error - SSU2: Runtime exception: cannot create std::vector larger than max_size()
i2pd_daemon_1 | 13:29:26@912/error - Tunnels: Can't select next hop for owK8lWcFqouCsZ2mskAdS8wK4pRxynR2nKEXWqowXyM=
i2pd_daemon_1 | 13:29:26@912/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 13:32:58@26/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 13:33:14@202/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 13:38:06@912/error - Tunnels: Can't select next hop for 27wfI1wBkp-5jDSPmtCiOuIBacgMxFbW0QxYpK1GpII=
i2pd_daemon_1 | 13:38:06@912/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 13:38:42@26/error - SSU2: RelayIntro unknown router to introduce
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.23 - - [Wed, 20 Dec 2023 13:49:37 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
server_1 |
server_1 | ::ffff:10.21.0.23 - - [Wed, 20 Dec 2023 13:49:44 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
server_1 |
server_1 | ::ffff:10.21.0.23 - - [Wed, 20 Dec 2023 13:49:47 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0"
server_1 |
bluewallet
Attaching to bluewallet_lndhub_1, bluewallet_app_proxy_1, bluewallet_redis_1, bluewallet_tor_server_1
lndhub_1 | at Object.onReceiveStatus (/lndhub/node_modules/@grpc/grpc-js/src/client-interceptors.ts:389:48)
lndhub_1 | at /lndhub/node_modules/@grpc/grpc-js/src/call-stream.ts:276:24
lndhub_1 | at processTicksAndRejections (node:internal/process/task_queues:78:11) {
lndhub_1 | code: 2,
lndhub_1 | details: 'wallet locked, unlock it to enable full RPC access',
lndhub_1 | metadata: Metadata {
lndhub_1 | internalRepr: Map(1) { 'content-type' => [Array] },
lndhub_1 | options: {}
lndhub_1 | }
lndhub_1 | }
app_proxy_1 | [HPM] Proxy created: / -> http://bluewallet_lndhub_1:3008
app_proxy_1 | Waiting for bluewallet_lndhub_1:3008 to open...
app_proxy_1 | BlueWallet Lightning is now ready...
app_proxy_1 | Listening on port: 3008
redis_1 | 7:C 19 Dec 2023 14:00:05.339 # Redis version=6.2.2, bits=64, commit=00000000, modified=0, pid=7, just started
redis_1 | 7:C 19 Dec 2023 14:00:05.339 # Configuration loaded
redis_1 | 7:M 19 Dec 2023 14:00:05.341 * monotonic clock: POSIX clock_gettime
redis_1 | 7:M 19 Dec 2023 14:00:05.345 * Running mode=standalone, port=6379.
redis_1 | 7:M 19 Dec 2023 14:00:05.345 # Server initialized
redis_1 | 7:M 19 Dec 2023 14:00:05.367 * Loading RDB produced by version 6.2.2
redis_1 | 7:M 19 Dec 2023 14:00:05.367 * RDB age 573 seconds
redis_1 | 7:M 19 Dec 2023 14:00:05.367 * RDB memory usage when created 0.81 Mb
redis_1 | 7:M 19 Dec 2023 14:00:05.368 * DB loaded from disk: 0.007 seconds
redis_1 | 7:M 19 Dec 2023 14:00:05.368 * Ready to accept connections
