Bitcoin Node Synchronized but Electrs stuck
Screenshot 2022-12-23 101645
The node run on a Pi 4 with 8GB
The umbrel.local don’t work, I access it with the IP
Could it be the problem ?
here are the logs :
seems that there is something wrong with SSL ? Not sure if it’s the problem and how to solve it ?
0.5.3
Flashed OS version
v0.5.1
Raspberry Pi Model
Revision : d03115
Serial : 10000000d0681310
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=41.3’C
Throttling
throttled=0x0
Mem: 7.8G 1.6G 3.7G 10M 2.4G 6.1G
Swap: 4.1G 0B 4.1G
total: 20.8%
bitcoin: 10%
electrs: 5.4%
lightning: 5.2%
mempool: 4.3%
system: 0%
Memory monitor logs
2022-10-16 17:16:10 Memory monitor running!
2022-10-30 15:13:21 Memory monitor running!
2022-11-26 13:51:58 Memory monitor running!
2022-12-23 07:20:19 Memory monitor running!
/dev/root 59G 3.0G 53G 6% /
/dev/sda1 916G 567G 304G 66% /home/umbrel/umbrel
Startup service logs
Dec 23 07:20:51 umbrel umbrel startup[1248]: Creating mempool_app_proxy_1 …
Dec 23 07:20:51 umbrel umbrel startup[1248]: Creating mempool_web_1 …
Dec 23 07:21:05 umbrel umbrel startup[1248]: Creating electrs_electrs_1 … done
Dec 23 07:21:05 umbrel umbrel startup[1248]: Creating electrs_app_1 …
Dec 23 07:21:08 umbrel umbrel startup[1248]: Creating bitcoin_app_proxy_1 … done
Dec 23 07:21:08 umbrel umbrel startup[1248]: Creating mempool_tor_server_1 … done
Dec 23 07:21:13 umbrel umbrel startup[1248]: Creating electrs_app_proxy_1 … done
Dec 23 07:21:14 umbrel umbrel startup[1248]: Creating electrs_tor_1 … done
Dec 23 07:21:14 umbrel umbrel startup[1248]: Creating lightning_tor_1 … done
Dec 23 07:21:17 umbrel umbrel startup[1248]: Creating bitcoin_tor_1 … done
Dec 23 07:21:21 umbrel umbrel startup[1248]: Creating bitcoin_tor_server_1 … done
Dec 23 07:21:23 umbrel umbrel startup[1248]: Creating lightning_app_proxy_1 … done
Dec 23 07:21:24 umbrel umbrel startup[1248]: Creating mempool_web_1 … done
Dec 23 07:21:28 umbrel umbrel startup[1248]: Creating mempool_api_1 … done
Dec 23 07:21:29 umbrel umbrel startup[1248]: Creating lightning_lnd_1 … done
Dec 23 07:21:30 umbrel umbrel startup[1248]: Creating mempool_app_proxy_1 … done
Dec 23 07:21:34 umbrel umbrel startup[1248]: Creating lightning_app_1 … done
Dec 23 07:21:36 umbrel umbrel startup[1248]: Creating bitcoin_bitcoind_1 … done
Dec 23 07:21:36 umbrel umbrel startup[1248]: Creating bitcoin_server_1 …
Dec 23 07:21:37 umbrel umbrel startup[1248]: Creating electrs_tor_server_1 … done
Dec 23 07:21:41 umbrel umbrel startup[1248]: Creating lightning_tor_server_1 … done
Dec 23 07:21:45 umbrel umbrel startup[1248]: Creating electrs_app_1 … done
Dec 23 07:21:48 umbrel umbrel startup[1248]: Creating mempool_mariadb_1 … done
Dec 23 07:21:59 umbrel umbrel startup[1248]: Creating bitcoin_server_1 … done
Dec 23 07:22:00 umbrel umbrel startup[1248]: Umbrel is now accessible at
Dec 23 07:22:00 umbrel umbrel startup[1248]: http://umbrel.local
Dec 23 07:22:00 umbrel umbrel startup[1248]: http://192.168.0.104
Dec 23 07:22:00 umbrel systemd[1]: Started Umbrel Startup Service.
Dec 23 07:22:36 umbrel passwd[8528]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Dec 23 07:19:19 umbrel external storage mounter[502]: Running external storage mount script…
Dec 23 07:19:19 umbrel external storage mounter[502]: Found device “CT1000MX 500SSD1”
Dec 23 07:19:19 umbrel external storage mounter[502]: Blacklisting USB device IDs against UAS driver…
Dec 23 07:19:19 umbrel external storage mounter[502]: Rebinding USB drivers…
Dec 23 07:19:19 umbrel external storage mounter[502]: Checking USB devices are back…
Dec 23 07:19:19 umbrel external storage mounter[502]: Waiting for USB devices…
Dec 23 07:19:20 umbrel external storage mounter[502]: Waiting for USB devices…
Dec 23 07:19:21 umbrel external storage mounter[502]: Waiting for USB devices…
Dec 23 07:19:22 umbrel external storage mounter[502]: Checking if the device is ext4…
Dec 23 07:19:24 umbrel external storage mounter[502]: Yes, it is ext4
Dec 23 07:19:24 umbrel external storage mounter[502]: Checking filesystem for corruption…
Dec 23 07:19:24 umbrel external storage mounter[502]: e2fsck 1.44.5 (15-Dec-2018)
Dec 23 07:19:25 umbrel external storage mounter[502]: umbrel: clean, 255325/61054976 files, 152477722/244190208 blocks
Dec 23 07:19:25 umbrel external storage mounter[502]: Mounting partition…
Dec 23 07:19:26 umbrel external storage mounter[502]: Checking if device contains an Umbrel install…
Dec 23 07:19:26 umbrel external storage mounter[502]: Yes, it contains an Umbrel install
Dec 23 07:19:26 umbrel external storage mounter[502]: Bind mounting external storage over local Umbrel installation…
Dec 23 07:19:26 umbrel external storage mounter[502]: Bind mounting external storage over local Docker data dir…
Dec 23 07:19:26 umbrel external storage mounter[502]: Bind mounting external storage to /swap
Dec 23 07:19:27 umbrel external storage mounter[502]: Bind mounting SD card root at /sd-card…
Dec 23 07:19:27 umbrel external storage mounter[502]: Checking Umbrel root is now on external storage…
Dec 23 07:19:28 umbrel external storage mounter[502]: Checking /var/lib/docker is now on external storage…
Dec 23 07:19:28 umbrel external storage mounter[502]: Checking /swap is now on external storage…
Dec 23 07:19:28 umbrel external storage mounter[502]: Setting up swapfile
Dec 23 07:19:45 umbrel external storage mounter[502]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 23 07:19:45 umbrel external storage mounter[502]: no label, UUID=1645930d-aa8f-47dc-a1c5-33883d42465f
Dec 23 07:19:45 umbrel external storage mounter[502]: Checking SD Card root is bind mounted at /sd-root…
Dec 23 07:19:45 umbrel external storage mounter[502]: Starting external drive mount monitor…
Dec 23 07:19:45 umbrel external storage mounter[502]: Mount script completed successfully!
Dec 23 07:19:45 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Fri 2022-12-23 07:19:14 UTC, end at Fri 2022-12-23 07:35:05 UTC. –
Dec 23 07:20:18 umbrel systemd[1]: Starting External Storage SDcard Updater…
Dec 23 07:20:18 umbrel external storage updater[1166]: Checking if SD card Umbrel is newer than external storage…
Dec 23 07:20:18 umbrel external storage updater[1166]: No, SD version is not newer, exiting.
Dec 23 07:20:18 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Removing bitcoin_bitcoind_1 …
Removing bitcoin_tor_1 …
Removing bitcoin_tor_server_1 …
Removing bitcoin_app_proxy_1 …
Removing bitcoin_tor_server_1 … done
Removing bitcoin_bitcoind_1 … done
Removing bitcoin_server_1 … done
Removing bitcoin_app_proxy_1 … done
Removing bitcoin_tor_1 … done
Going to remove bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_tor_1, bitcoin_tor_server_1, bitcoin_app_proxy_1
Stopping Docker services…
Stopping nginx …
Stopping tor_server …
Stopping manager …
Stopping dashboard …
Stopping auth …
Stopping tor_proxy …
Stopping tor_server … done
Stopping tor_proxy … done
Stopping nginx … done
Stopping auth … done
Stopping dashboard … done
Stopping manager … done
Removing nginx …
Removing tor_server …
Removing manager …
Removing dashboard …
Removing auth …
Removing tor_proxy …
Removing tor_server … done
Removing dashboard … done
Removing nginx … done
Removing tor_proxy … done
Removing auth … done
Removing manager … done
Got signal:
karen is getting triggered!
Got signal:
Got signal: change-password
Got signal: debug
Docker containers
NAMES STATUS
bitcoin_server_1 Up 14 minutes
electrs_app_1 Up 14 minutes
mempool_api_1 Up 15 minutes
mempool_app_proxy_1 Up 15 minutes
mempool_web_1 Up 15 minutes
mempool_tor_server_1 Up 14 minutes
mempool_mariadb_1 Up 14 minutes
lightning_app_proxy_1 Up 15 minutes
lightning_lnd_1 Up 15 minutes
lightning_tor_server_1 Up 14 minutes
lightning_app_1 Up 15 minutes
lightning_tor_1 Up 15 minutes
electrs_electrs_1 Up 15 minutes
electrs_tor_server_1 Up 15 minutes
electrs_app_proxy_1 Up 15 minutes
electrs_tor_1 Up 15 minutes
bitcoin_bitcoind_1 Up 15 minutes
bitcoin_app_proxy_1 Up 15 minutes
bitcoin_tor_1 Up 15 minutes
bitcoin_tor_server_1 Up 15 minutes
nginx Up 15 minutes
tor_server Up 16 minutes
dashboard Up 16 minutes
manager Up 16 minutes
tor_proxy Up 16 minutes
auth Up 16 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:36 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:36 GMT] “GET /v1/system/temperature HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:36 GMT] “GET /v1/system/memory HTTP/1.0” 200 602 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:37 GMT] “GET /v1/system/storage HTTP/1.0” 200 611 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:37 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:37 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:37 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:37 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:38 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 23 Dec 2022 07:36:39 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Dec 23 07:34:02.000 [warn] 16 connections have failed:
tor_proxy | Dec 23 07:34:02.000 [warn] 16 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy | Dec 23 07:34:30.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:0. Giving up. (waiting for circuit)
tor_proxy | Dec 23 07:34:49.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 18; recommendation warn; host 847B1F850344D7876491A54892F904934E4EB85D at 86.59.21.38:443)
tor_proxy | Dec 23 07:34:49.000 [warn] 17 connections have failed:
tor_proxy | Dec 23 07:34:49.000 [warn] 17 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy | Dec 23 07:36:19.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 19; recommendation warn; host 49E5FB957045FDDC8C53255CEB6BA653E1E9AA5D at 185.239.222.240:443)
tor_proxy | Dec 23 07:36:19.000 [warn] 18 connections have failed:
tor_proxy | Dec 23 07:36:19.000 [warn] 18 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy | Dec 23 07:36:30.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:53. Giving up. (waiting for circuit)
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1, bitcoin_tor_1, bitcoin_tor_server_1
app_proxy_1 | Validating token: 3e3690ff133f …
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.3 - - [Fri, 23 Dec 2022 07:34:01 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.3 - - [Fri, 23 Dec 2022 07:34:06 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.3 - - [Fri, 23 Dec 2022 07:34:11 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
server_1 |
tor_1 | Dec 23 07:35:28.000 [warn] 20 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:28.000 [warn] 1 connections died in state handshaking (Tor, v3 handshake) with SSL state SSL negotiation finished successfully in OPEN
tor_1 | Dec 23 07:35:28.000 [warn] Problem bootstrapping. Stuck at 14% (handshake): Handshaking with a relay. (Connection timed out; TIMEOUT; count 23; recommendation warn; host 6389ECB4891334B846300FDD8A68250EBB5B7C52 at 185.82.219.85:9001)
tor_1 | Dec 23 07:35:28.000 [warn] 22 connections have failed:
tor_1 | Dec 23 07:35:28.000 [warn] 21 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:36:42.000 [warn] Problem bootstrapping. Stuck at 14% (handshake): Handshaking with a relay. (Connection timed out; TIMEOUT; count 24; recommendation warn; host 04651736C657C20313887CB9F10DA953C3B5C5A5 at 95.214.54.164:8444)
tor_1 | Dec 23 07:36:42.000 [warn] 23 connections have failed:
tor_1 | Dec 23 07:36:42.000 [warn] 22 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:36:42.000 [warn] 1 connections died in state handshaking (Tor, v3 handshake) with SSL state SSL negotiation finished successfully in OPEN
bitcoind_1 | 2022-12-23T07:24:27Z Imported mempool transactions from disk: 4417 succeeded, 0 failed, 0 expired, 0 already there, 0 waiting for initial broadcast
bitcoind_1 | 2022-12-23T07:24:27Z loadblk thread exit
bitcoind_1 | 2022-12-23T07:29:08Z Loading addresses from DNS seed seed.btc.petertodd.org.
bitcoind_1 | 2022-12-23T07:29:08Z Loading addresses from DNS seed dnsseed.emzy.de.
bitcoind_1 | 2022-12-23T07:29:08Z Loading addresses from DNS seed seed.bitcoin.sipa.be.
bitcoind_1 | 2022-12-23T07:29:08Z Waiting 300 seconds before querying DNS seeds.
bitcoind_1 | 2022-12-23T07:34:08Z Loading addresses from DNS seed seed.bitcoin.wiz.biz.
bitcoind_1 | 2022-12-23T07:34:08Z Loading addresses from DNS seed seed.bitcoinstats.com.
bitcoind_1 | 2022-12-23T07:34:08Z Loading addresses from DNS seed dnsseed.bluematt.me.
bitcoind_1 | 2022-12-23T07:34:08Z Waiting 300 seconds before querying DNS seeds.
electrs
Attaching to electrs_app_1, electrs_electrs_1, electrs_tor_server_1, electrs_app_proxy_1, electrs_tor_1
app_1 | umbrel-middleware
app_1 | ::ffff:10.21.0.6 - - [Fri, 23 Dec 2022 07:34:19 GMT] “GET /fonts/Inter-Regular.woff2?v=3.19 HTTP/1.1” 304 - “http://192.168.0.104:2102/css/app.30e1a22b.css” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
app_1 |
app_1 | ::ffff:10.21.0.6 - - [Fri, 23 Dec 2022 07:34:19 GMT] “GET /fonts/Inter-Medium.woff2?v=3.19 HTTP/1.1” 304 - “http://192.168.0.104:2102/css/app.30e1a22b.css” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
app_1 |
app_1 | ::ffff:10.21.0.6 - - [Fri, 23 Dec 2022 07:34:19 GMT] “GET /fonts/Inter-Bold.woff2?v=3.19 HTTP/1.1” 304 - “http://192.168.0.104:2102/css/app.30e1a22b.css” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”
app_1 |
electrs_1 | [2022-12-23T07:24:00.050Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:01.053Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:02.056Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:03.058Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:04.060Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:05.063Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:06.066Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:07.068Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:24:08.071Z INFO electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1 | [2022-12-23T07:33:16.481Z INFO electrs::electrum] your wallet uses less efficient method of querying electrs, consider contacting the developer of your wallet. Reason: blockchain.scripthash.get_balance called for unsubscribed scripthash
tor_1 | Dec 23 07:33:29.000 [warn] 18 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:24.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 20; recommendation warn; host CF6D0AAFB385BE71B8E111FC5CFF4B47923733BC at 154.35.175.225:443)
tor_1 | Dec 23 07:35:24.000 [warn] 19 connections have failed:
tor_1 | Dec 23 07:35:24.000 [warn] 19 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:24.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 21; recommendation warn; host D8A2D0080B0C73E1DC0EC9F33B497F64E5FB3F52 at 136.243.176.148:443)
tor_1 | Dec 23 07:35:24.000 [warn] 20 connections have failed:
tor_1 | Dec 23 07:35:24.000 [warn] 20 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:28.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 22; recommendation warn; host 5412D862C7625F145E16D3D831F6D33A9FAF5EE9 at 139.99.172.11:9001)
tor_1 | Dec 23 07:35:28.000 [warn] 21 connections have failed:
lightning
Attaching to lightning_app_proxy_1, lightning_lnd_1, lightning_tor_server_1, lightning_app_1, lightning_tor_1
app_1 | [backup-monitor] Error: Proxy connection timed out
app_1 | [backup-monitor] Sleeping…
app_1 | Checking LND status…
app_1 | LND already unlocked!
app_1 | [backup-monitor] Checking channel backup…
app_1 | [backup-monitor] Channel backup has changed, backing up!
app_proxy_1 | [HPM] Proxy created: / -> http://10.21.22.3:3006
app_proxy_1 | Waiting for 10.21.22.3:3006 to open…
app_proxy_1 | Lightning Node is now ready…
app_proxy_1 | Listening on port: 2101
lnd_1 | 2022-12-23 07:30:23.347 [INF] DISC: Attempting to bootstrap with: Authenticated Channel Graph
lnd_1 | 2022-12-23 07:30:23.404 [INF] DISC: Obtained 3 addrs to bootstrap network with
lnd_1 | 2022-12-23 07:30:30.406 [INF] DISC: Attempting to bootstrap with: BOLT-0010 DNS Seed: [[nodes.lightning.directory soa.nodes.lightning.directory] [lseed.bitcoinstats.com ]]
lnd_1 | 2022-12-23 07:36:30.839 [INF] DISC: Attempting to bootstrap with: Authenticated Channel Graph
lnd_1 | 2022-12-23 07:36:30.918 [INF] DISC: Obtained 3 addrs to bootstrap network with
lnd_1 | 2022-12-23 07:36:41.920 [INF] DISC: Attempting to bootstrap with: Authenticated Channel Graph
lnd_1 | 2022-12-23 07:36:41.944 [INF] DISC: Obtained 3 addrs to bootstrap network with
tor_1 | Dec 23 07:34:43.000 [warn] 17 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:26.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 19; recommendation warn; host 9695DFC35FFEB861329B9F1AB04C46397020CE31 at 128.31.0.39:9101)
tor_1 | Dec 23 07:35:26.000 [warn] 18 connections have failed:
tor_1 | Dec 23 07:35:26.000 [warn] 18 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:35:26.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 20; recommendation warn; host 1EBFC733CCD952F7F7616EBBA7BC6B8E6F2F0CBC at 94.130.58.99:9001)
tor_1 | Dec 23 07:35:26.000 [warn] 19 connections have failed:
tor_1 | Dec 23 07:35:26.000 [warn] 19 connections died in state connect()ing with SSL state (No SSL object)
tor_1 | Dec 23 07:36:42.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 21; recommendation warn; host 1C7700A94DBBFECFA234C1ADD0D23FB87D1D7599 at 185.220.102.244:443)
tor_1 | Dec 23 07:36:42.000 [warn] 20 connections have failed:
tor_1 | Dec 23 07:36:42.000 [warn] 20 connections died in state connect()ing with SSL state (No SSL object)
mempool
Attaching to mempool_api_1, mempool_app_proxy_1, mempool_web_1, mempool_tor_server_1, mempool_mariadb_1
api_1 | Dec 23 07:23:29 [163] INFO: List of public pools will be queried over clearnet
api_1 | Dec 23 07:23:35 [163] WARN: runMainLoop error: Verifying blocks…. Retrying in 10 sec.
api_1 | Dec 23 07:23:45 [163] WARN: runMainLoop error: Verifying blocks…. Retrying in 20 sec.
api_1 | Dec 23 07:24:05 [163] WARN: runMainLoop error: Verifying blocks…. Retrying in 40 sec.
api_1 | Dec 23 07:24:09 [163] INFO: Connected to Electrum Server at 10.21.21.10:50001 ([“electrs/0.9.9”,“1.4”])
api_1 | Dec 23 07:25:06 [163] NOTICE: The mempool is now in sync!
api_1 | Dec 23 07:25:07 [163] INFO: Indexed 0 blocks
api_1 | Dec 23 07:25:08 [163] INFO: 54058 blocks hash validated in 341 ms
api_1 | Dec 23 07:25:08 [163] INFO: Indexed 11 day of network hashrate
api_1 | Dec 23 07:25:08 [163] INFO: Indexed 140 pools weekly hashrate
app_proxy_1 | [HPM] Proxy created: / -> http://10.21.21.26:3006
app_proxy_1 | Waiting for 10.21.21.26:3006 to open…
app_proxy_1 | mempool is now ready…
app_proxy_1 | Listening on port: 3006
app_proxy_1 | [HPM] Upgrading to WebSocket
app_proxy_1 | [HPM] Client disconnected
mariadb_1 | 2022-12-23 7:22:21 0 [Note] Plugin ‘FEEDBACK’ is disabled.
mariadb_1 | 2022-12-23 7:22:22 0 [Note] Server socket created on IP: ‘::’.
mariadb_1 | 2022-12-23 7:22:23 0 [Warning] ‘proxies_priv’ entry ‘@% root@e06028dd76cc’ ignored in --skip-name-resolve mode.
mariadb_1 | 2022-12-23 7:22:28 0 [Note] Reading of all Master_info entries succeeded
mariadb_1 | 2022-12-23 7:22:28 0 [Note] Added new Master_info ‘’ to hash table
mariadb_1 | 2022-12-23 7:22:28 0 [Note] mysqld: ready for connections.
mariadb_1 | Version: ‘10.5.12-MariaDB-1:10.5.12+maria~focal’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
mariadb_1 | 2022-12-23 7:22:28 4 [Warning] Aborted connection 4 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.26’ (This connection closed normally without authentication)
mariadb_1 | 2022-12-23 7:22:28 3 [Warning] Aborted connection 3 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2022-12-23 7:22:39 0 [Note] InnoDB: Buffer pool(s) load completed at 221223 7:22:39
==== Result ====
I posted this question yesterday but haven’t received a response to it.
Are you running a pruned node? If so, I have noticed that when going from a full node to a pruned node electrs will not sync. So now, I have to wait until my umbrel downloads the whole btc blockchain again before i can use my mobile wallets again. Wish I had know that electrs would not work with a pruned node before I had used the new umbrel update to prune it.
