Cannot open Bitcoin/Lightning Nodes!
cannot access bitcoin node or lightning node. will not connect to mempool. i reflashed latest umbrel OS. i have funds in bitcoin wallet. i must access them!! please help
Startup service logs
Oct 22 18:42:30 umbrel umbrel startup[2235]: Creating lightning_tor_1 … done
Oct 22 18:42:30 umbrel umbrel startup[2235]: Creating lightning_tor_server_1 … done
Oct 22 18:42:30 umbrel umbrel startup[2235]: Creating mempool_app_proxy_1 … done
Oct 22 18:42:30 umbrel umbrel startup[2235]: Creating mempool_mariadb_1 … done
Oct 22 18:42:30 umbrel umbrel startup[2235]: Creating lightning_app_proxy_1 … done
Oct 22 18:42:35 umbrel umbrel startup[2235]: Creating electrs_app_proxy_1 … done
Oct 22 18:42:37 umbrel umbrel startup[2235]: Creating electrs_tor_1 … done
Oct 22 18:42:39 umbrel umbrel startup[2235]: Creating lightning-terminal_web_1 … done
Oct 22 18:42:39 umbrel umbrel startup[2235]: Creating bitcoin_i2pd_daemon_1 … done
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating bitcoin_bitcoind_1 … done
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating lightning-terminal_tor_server_1 … done
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating bitcoin_tor_1 … done
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating electrs_electrs_1 … done
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating bitcoin_server_1 …
Oct 22 18:42:40 umbrel umbrel startup[2235]: Creating electrs_app_1 …
Oct 22 18:42:41 umbrel umbrel startup[2235]: Creating bitcoin_tor_server_1 … done
Oct 22 18:42:41 umbrel umbrel startup[2235]: Creating lightning-terminal_app_proxy_1 … done
Oct 22 18:42:41 umbrel umbrel startup[2235]: Creating electrs_tor_server_1 … done
Oct 22 18:42:42 umbrel umbrel startup[2235]: Creating lightning_app_1 … done
Oct 22 18:42:42 umbrel umbrel startup[2235]: Creating lightning_lnd_1 … done
Oct 22 18:42:42 umbrel umbrel startup[2235]: Creating bitcoin_app_proxy_1 … done
Oct 22 18:42:47 umbrel umbrel startup[2235]: Creating bitcoin_server_1 … done
Oct 22 18:42:48 umbrel umbrel startup[2235]: Creating electrs_app_1 … done
Oct 22 18:42:49 umbrel umbrel startup[2235]: Umbrel is now accessible at
Oct 22 18:42:49 umbrel umbrel startup[2235]: http://umbrel.local
Oct 22 18:42:49 umbrel umbrel startup[2235]: http://10.0.0.190
Oct 22 18:42:49 umbrel systemd[1]: Started Umbrel Startup Service.
Oct 22 18:45:52 umbrel passwd[22174]: pam_unix(passwd:chauthtok): password changed for umbrel
Oct 22 18:47:23 umbrel passwd[27896]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Oct 16 13:26:03 umbrel external storage mounter[511]: Waiting for USB devices…
Oct 16 13:26:04 umbrel external storage mounter[511]: Checking if the device is ext4…
Oct 16 13:26:05 umbrel external storage mounter[511]: Yes, it is ext4
Oct 16 13:26:05 umbrel external storage mounter[511]: Checking filesystem for corruption…
Oct 16 13:26:05 umbrel external storage mounter[511]: e2fsck 1.44.5 (15-Dec-2018)
Oct 16 13:26:05 umbrel external storage mounter[511]: umbrel: recovering journal
Oct 16 13:26:13 umbrel external storage mounter[511]: Clearing orphaned inode 12714043 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 16 13:26:13 umbrel external storage mounter[511]: Clearing orphaned inode 12714042 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 16 13:26:13 umbrel external storage mounter[511]: Clearing orphaned inode 12714041 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 16 13:26:13 umbrel external storage mounter[511]: Clearing orphaned inode 12714000 (uid=1000, gid=1000, mode=0100600, size=0)
Oct 16 13:26:13 umbrel external storage mounter[511]: Setting free inodes count to 60771795 (was 60773662)
Oct 16 13:26:13 umbrel external storage mounter[511]: Setting free blocks count to 75425784 (was 76844487)
Oct 16 13:26:13 umbrel external storage mounter[511]: umbrel: clean, 283181/61054976 files, 168764424/244190208 blocks
Oct 16 13:26:13 umbrel external storage mounter[511]: Mounting partition…
Oct 16 13:26:13 umbrel external storage mounter[511]: Checking if device contains an Umbrel install…
Oct 16 13:26:13 umbrel external storage mounter[511]: Yes, it contains an Umbrel install
Oct 16 13:26:13 umbrel external storage mounter[511]: Bind mounting external storage over local Umbrel installation…
Oct 16 13:26:13 umbrel external storage mounter[511]: Bind mounting external storage over local Docker data dir…
Oct 16 13:26:13 umbrel external storage mounter[511]: Bind mounting external storage to /swap
Oct 16 13:26:13 umbrel external storage mounter[511]: Bind mounting SD card root at /sd-card…
Oct 16 13:26:13 umbrel external storage mounter[511]: Checking Umbrel root is now on external storage…
Oct 16 13:26:16 umbrel external storage mounter[511]: Checking /var/lib/docker is now on external storage…
Oct 16 13:26:16 umbrel external storage mounter[511]: Checking /swap is now on external storage…
Oct 16 13:26:16 umbrel external storage mounter[511]: Setting up swapfile
Oct 16 13:26:16 umbrel external storage mounter[511]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Oct 16 13:26:16 umbrel external storage mounter[511]: no label, UUID=20e42c6b-ff99-4c56-89fd-af9686450bfd
Oct 16 13:26:16 umbrel external storage mounter[511]: Checking SD Card root is bind mounted at /sd-root…
Oct 16 13:26:16 umbrel external storage mounter[511]: Starting external drive mount monitor…
Oct 16 13:26:16 umbrel external storage mounter[511]: Mount script completed successfully!
Oct 16 13:26:16 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Mon 2023-10-16 13:25:49 UTC, end at Sun 2023-10-22 18:51:51 UTC. –
Oct 22 18:41:47 umbrel systemd[1]: Starting External Storage SDcard Updater…
Oct 22 18:41:47 umbrel external storage updater[2157]: Checking if SD card Umbrel is newer than external storage…
Oct 22 18:41:47 umbrel external storage updater[2157]: No, SD version is not newer, exiting.
Oct 22 18:41:47 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
1+0 records in
1+0 records out
3895 bytes (3.9 kB, 3.8 KiB) copied, 0.000251405 s, 15.5 MB/s
Creating encrypted tarball…
backup/
backup/.padding
backup/channel.backup
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0curl: (6) Could not resolve host: pvf3ozmmfl.execute-api.us-east-1.amazonaws.com
====== Backup failed =======
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
7753 bytes (7.8 kB, 7.6 KiB) copied, 0.000365663 s, 21.2 MB/s
backup/
backup/.padding
Uploading backup…
Got signal:
Got signal:
Got signal: change-password
Got signal: debug
Docker containers
NAMES STATUS
electrs_app_1 Up 9 minutes
bitcoin_server_1 Up 9 minutes
bitcoin_app_proxy_1 Up 9 minutes
lightning-terminal_web_1 Up 9 minutes
bitcoin_tor_server_1 Up 9 minutes
lightning-terminal_app_proxy_1 Up 9 minutes
lightning-terminal_tor_server_1 Up 9 minutes
bitcoin_bitcoind_1 Restarting (1) 56 seconds ago
bitcoin_i2pd_daemon_1 Up 9 minutes
bitcoin_tor_1 Up 9 minutes
electrs_tor_server_1 Up 9 minutes
electrs_electrs_1 Up 9 seconds
electrs_tor_1 Up 9 minutes
lightning_tor_server_1 Up 9 minutes
electrs_app_proxy_1 Up 9 minutes
lightning_app_1 Up 9 minutes
lightning_lnd_1 Up 9 minutes
lightning_tor_1 Up 9 minutes
lightning_app_proxy_1 Up 9 minutes
mempool_app_proxy_1 Up 9 minutes
mempool_tor_server_1 Up 9 minutes
mempool_api_1 Up 6 seconds
mempool_mariadb_1 Up 9 minutes
mempool_web_1 Up 9 minutes
snowflake_web_1 Up 9 minutes
vaultwarden_server_1 Up 9 minutes (healthy)
vaultwarden_app_proxy_1 Up 9 minutes
vaultwarden_tor_server_1 Up 9 minutes
snowflake_proxy_1 Up 9 minutes
snowflake_app_proxy_1 Up 9 minutes
snowflake_tor_server_1 Up 9 minutes
nginx Up 9 minutes
tor_proxy Up 9 minutes
dashboard Up 9 minutes
auth Up 9 minutes
tor_server Up 9 minutes
manager Up 9 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:55 GMT] “GET /v1/system/storage HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:55 GMT] “GET /v1/system/temperature HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:55 GMT] “GET /v1/system/is-sd-card-failing HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:56 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:56 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:56 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:56 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:56 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:51:58 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 22 Oct 2023 18:52:00 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Oct 22 18:42:14.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 18:42:14.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 18:42:15.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_proxy | Oct 22 18:42:15.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Oct 22 18:42:15.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Oct 22 18:42:15.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Oct 22 18:42:15.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Oct 22 18:42:16.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Oct 22 18:42:16.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Oct 22 18:42:17.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_app_proxy_1, bitcoin_tor_server_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_tor_1
bitcoind_1 | Error: Settings file could not be read:
bitcoind_1 | - Unable to parse settings file /data/.bitcoin/settings.json
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t select next hop for phRQrMwNkNUgLF–HHwmmO~N8BByQ8RlcQkp5cH1WbI=
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t create outbound tunnel, no peers available
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t select next hop for QGWIAAybxcU~zps6YmGGNEklZNaf6CJn5PSrs~zfWkQ=
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t select next hop for xlo9a5ceiiK137Ypk3Pz25NiBVSI4–GX4D~JjMwphc=
i2pd_daemon_1 | 18:51:54@858/error - Tunnels: Can’t select next hop for NA~k5oM21ZQBTI3TlsHX4CfNKKxqL6tqN9ORCJF5HTc=
app_proxy_1 | Validating token: 45b9749b58d6 …
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.21 - - [Sun, 22 Oct 2023 18:51:46 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
server_1 |
server_1 | ::ffff:10.21.0.21 - - [Sun, 22 Oct 2023 18:51:52 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
server_1 |
server_1 | ::ffff:10.21.0.21 - - [Sun, 22 Oct 2023 18:52:04 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:109.0) Gecko/20100101 Firefox/115.0”
server_1 |
tor_1 | Oct 22 18:43:17.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:18.000 [notice] Bootstrapped 66% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:18.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Oct 22 18:43:21.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Oct 22 18:43:21.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Oct 22 18:43:21.000 [notice] Bootstrapped 100% (done): Done
electrs
Attaching to electrs_app_1, electrs_tor_server_1, electrs_electrs_1, electrs_tor_1, electrs_app_proxy_1
electrs_1 | [2023-10-22T18:52:01.906Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs_1 | 1: No such file or directory (os error 2)
electrs_1 | Starting electrs 0.9.14 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, skip_block_download_wait: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.9.14)”, signet_magic: f9beb4d9, args: }
app_1 | > umbrel-electrs@1.0.1 dev:backend
app_1 | > npm run start -w umbrel-electrs-backend
app_1 |
app_1 |
app_1 | > umbrel-electrs-backend@0.1.12 start
app_1 | > node ./bin/www
app_1 |
app_1 | Sun, 22 Oct 2023 18:43:23 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:28:9
app_1 | Sun, 22 Oct 2023 18:43:23 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1 | Listening on port 3006
electrs_1 | [2023-10-22T18:52:03.871Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2023-10-22T18:52:03.871Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2023-10-22T18:52:03.955Z INFO electrs::db] “/data/db/bitcoin”: 171 SST files, 41.249813719 GB, 5.170234361 Grows
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.4:3006
app_proxy_1 | Waiting for 10.21.22.4:3006 to open…
app_proxy_1 | Electrs is now ready…
app_proxy_1 | Listening on port: 2102
tor_1 | Oct 22 18:43:14.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 62% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:17.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:19.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Oct 22 18:43:19.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Oct 22 18:43:19.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Oct 22 18:43:19.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Oct 22 18:43:20.000 [notice] Bootstrapped 100% (done): Done
lightning
Attaching to lightning_tor_server_1, lightning_app_1, lightning_lnd_1, lightning_tor_1, lightning_app_proxy_1
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.3:3006
app_proxy_1 | Waiting for 10.21.22.3:3006 to open…
app_proxy_1 | Lightning Node is now ready…
app_proxy_1 | Listening on port: 2101
app_1 | Waiting for LND…
app_1 | Checking LND status…
lnd_1 | 2023-10-22 18:50:38.538 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:50:38.555 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:50:59.613 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:50:59.632 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:51:21.869 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:51:21.897 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:51:46.953 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:51:46.980 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:52:11.754 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-10-22 18:52:11.774 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
tor_1 | Oct 22 18:43:12.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:14.000 [notice] Bootstrapped 62% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:14.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Oct 22 18:43:15.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Oct 22 18:43:16.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Oct 22 18:43:17.000 [notice] Bootstrapped 100% (done): Done
lightning-terminal
Attaching to lightning-terminal_web_1, lightning-terminal_app_proxy_1, lightning-terminal_tor_server_1
app_proxy_1 | [HPM] Proxy created: / → http://lightning-terminal_web_1:3004
app_proxy_1 | Waiting for lightning-terminal_web_1:3004 to open…
app_proxy_1 | Lightning Terminal is now ready…
app_proxy_1 | Listening on port: 3004
web_1 | LiT Version 0.10.5-alpha commit=v0.10.5-alpha
web_1 | Web interface 127.0.0.1:8443, 0.0.0.0:3004 (open https://127.0.0.1:8443 or http://localhost:3004 in your browser)
web_1 | ----------------------------------------------------------
web_1 | 2023-10-22 18:42:52.426 [INF] LITD: Connecting basic lnd client
web_1 | 2023-10-22 18:42:52.630 [INF] LITD: Connecting full lnd client
web_1 | 2023-10-22 18:42:52.630 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
web_1 | 2023-10-22 18:42:52.630 [INF] LNDC: Connected to lnd
web_1 | 2023-10-22 18:42:52.710 [INF] LNDC: Waiting for lnd to unlock
web_1 | 2023-10-22 18:42:52.863 [INF] LNDC: Wallet state of lnd is now: Lnd is waiting to start
web_1 | 2023-10-22 18:43:04.219 [INF] LNDC: Wallet state of lnd is now: Wallet is locked
mempool
Attaching to mempool_app_proxy_1, mempool_tor_server_1, mempool_api_1, mempool_mariadb_1, mempool_web_1
mariadb_1 | 2023-10-22 18:50:41 34 [Warning] Aborted connection 34 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-10-22 18:50:43 35 [Warning] Aborted connection 35 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-10-22 18:51:02 36 [Warning] Aborted connection 36 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-10-22 18:51:03 37 [Warning] Aborted connection 37 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-10-22 18:51:25 38 [Warning] Aborted connection 38 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-10-22 18:51:26 39 [Warning] Aborted connection 39 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-10-22 18:51:50 40 [Warning] Aborted connection 40 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-10-22 18:51:51 41 [Warning] Aborted connection 41 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-10-22 18:52:15 42 [Warning] Aborted connection 42 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-10-22 18:52:16 43 [Warning] Aborted connection 43 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.26:3006
app_proxy_1 | Waiting for 10.21.21.26:3006 to open…
app_proxy_1 | mempool is now ready…
app_proxy_1 | Listening on port: 3006
api_1 | Error: connect EHOSTUNREACH 10.21.21.8:8332
api_1 | at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1187:16) {
api_1 | errno: -113,
api_1 | code: ‘EHOSTUNREACH’,
api_1 | syscall: ‘connect’,
api_1 | address: ‘10.21.21.8’,
api_1 | port: 8332
api_1 | }
api_1 | wait-for-it.sh: waiting 720 seconds for mariadb:3306
api_1 | wait-for-it.sh: mariadb:3306 is available after 0 seconds
web_1 | /var/www/mempool/browser/resources
snowflake
Attaching to snowflake_web_1, snowflake_proxy_1, snowflake_app_proxy_1, snowflake_tor_server_1
proxy_1 | 2023/10/22 18:42:22 snowflake-proxy 2.4.1
proxy_1 | 2023/10/22 18:42:22 Proxy starting
proxy_1 | 2023/10/22 18:42:22 WebRTC: Created offer
proxy_1 | 2023/10/22 18:42:22 WebRTC: Set local description
proxy_1 | 2023/10/22 18:42:27 Offer: {“type”:“offer”,“sdp”:“v=0\r\no=- 312483372449453396 1698000142 IN IP4 [scrubbed]\r\ns=-\r\nt=0 0\r\na=fingerprint:sha-256 17:03:9E:62:7F:34:3E:1F:3B:0D:53:7F:D3:DC:71:15:5E:E7:DD:25:08:F3:F6:C1:DF:69:9E:23:34:6F:1F:BD\r\na=extmap-allow-mixed\r\na=group:BUNDLE 0\r\nm=application 9 UDP/DTLS/SCTP webrtc-datachannel\r\nc=IN IP4 [scrubbed]\r\na=setup:actpass\r\na=mid:0\r\na=sendrecv\r\na=sctp-port:5000\r\na=ice-ufrag:gbyqQEzXMSHkwgZf\r\na=ice-pwd:qAoYwcucineUTJGNRSYGjVUwRrzLXoLX\r\na=candidate:935314439 1 udp 2130706431 [scrubbed] 35729 typ host\r\na=candidate:935314439 2 udp 2130706431 [scrubbed] 35729 typ host\r\na=end-of-candidates\r\n”}
proxy_1 | 2023/10/22 18:42:55 NAT Type measurement: unknown → restricted = restricted
proxy_1 | 2023/10/22 18:42:55 NAT type: restricted
web_1 | 2023/10/22 18:42:26 Using index file at /snowflake/index.html
web_1 | 2023/10/22 18:42:27 Server is starting with command: bash -c tail -n 10000 -f /snowflake/snowflake.log | grep “Traffic Relayed”
web_1 | 2023/10/22 18:42:27 URL: http://127.0.0.1:3800/
web_1 | 2023/10/22 18:42:27 URL: http://10.21.0.8:3800/
app_proxy_1 | [HPM] Proxy created: / → http://snowflake_web_1:3800
app_proxy_1 | Waiting for snowflake_web_1:3800 to open…
app_proxy_1 | Tor Snowflake Proxy is now ready…
app_proxy_1 | Listening on port: 3800
vaultwarden
Attaching to vaultwarden_server_1, vaultwarden_app_proxy_1, vaultwarden_tor_server_1
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.46:8089
app_proxy_1 | Waiting for 10.21.21.46:8089 to open…
app_proxy_1 | Vaultwarden is now ready…
app_proxy_1 | Listening on port: 8089
server_1 | | official channels to report bugs/features, regardless of client. |
server_1 | | Send usage/configuration questions or feature requests to: |
server_1 | | https://vaultwarden.discourse.group/ |
server_1 | | Report suspected bugs/issues in the software itself at: |
server_1 | | Sign in to GitHub · GitHub |
server_1 | --------------------------------------------------------------------/
server_1 |
server_1 | [INFO] No .env file found.
server_1 |
server_1 | [2023-10-22 18:42:27.385][start][INFO] Rocket has launched from http://0.0.0.0:8089
==== Result ====
Hi can I ask what you have Umbrel set-up on? It almost seems like it is having trouble connecting to the internet outside of your local network.
Also please try the following:
BTW if you have your seed phrase written down, there shouldn’t be any issue restoring this onto other wallet software in the meantime while we resolve this
Thanks for your response. Below is software version, and my hardware device. I can access my node from anywhere, but it is not syncing. Both BTC and LND nodes are not accessible. I wrote down the 8-word seed phrase a couple years ago. What type of BTC wallet is recommended to restore my old wallet?
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03114
Serial : 1000000064f19306
The above commands worked. I was able to access my wallets after 6 months of being locked out.
Thank you!
Thanks this seemed to solve my issue.
For some reason the ~/umbrel/app-data/bitcoin/data/bitcoin/settings.json file was empty but present.
Removing it and restarting all the containers worked (I’m still catching up a day’s worth of missed blocks).
