Bitcoin node stuck on not running
My Bitcoin node has been stuck on “Not Running” for several days now. I have tried re-starting and shutting down. Also Electrs has been stuck at 1% updating during this time too. I am up to date running Umbrel OS 1.4.
My Bitcoin Node Logs:
Command failed with exit code 1: /opt/umbreld/source/modules/apps/legacy-compat/app-script logs bitcoin
time=“2025-03-17T21:59:02Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-03-17T21:59:02Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.tor.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-03-17T21:59:02Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-03-17T21:59:02Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_TOR_PROXY_IP" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_I2P_DAEMON_IP" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_IP" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_DATA_DIR" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_RPC_USER" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_RPC_PORT" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_P2P_HIDDEN_SERVICE" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_P2P_PORT" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_RPC_PASS" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_RPC_HIDDEN_SERVICE" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_NODE_IP" variable is not set. Defaulting to a blank string.”
time=“2025-03-17T21:59:02Z” level=warning msg=“The "APP_BITCOIN_COMMAND" variable is not set. Defaulting to a blank string.”
invalid spec: :/data/.bitcoin: empty section between colons
Did you try to restart your device
Yes, I did.
Maybe you updated umbrel IOS and not bitcoin core app, electrum ect?
Try this solution but adapt it with the Bitcoin Node app information.
Solution:
I had a similar problem. Turned out that my Umbrel was running out of storage space. I upgraded my external hard drive, and now it is working good.
