impossible to run bitcoin node always starting on pi4
umbrel run well
umbrel run well
Command failed with exit code 1: /opt/umbreld/source/modules/apps/legacy-compat/app-script logs bitcoin
time=“2025-10-20T16:51:32Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-10-20T16:51:32Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-10-20T16:51:32Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
time=“2025-10-20T16:51:32Z” level=warning msg=“/home/umbrel/umbrel/app-data/bitcoin/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
So from this I suggest doing these two things.
Hope that helps!
Ive been running umbrel on a pi4 for a couple years without any major issue so it is not impossible.
Have you tried reflashing with the latest version
thank you
but nothing can change my problem it has many problems since six month
flashed umbrella many times after problems of connection reset many times uninstall bitcoin reinstall
bitcoin its a nightmare
finally I loaded umbrel beta 1.5 and problem is fixed
now waiting for evolution
