I installed Umbrel and it completed ok. When I installed Bitcoin node and run it, after a few mins , right 10-14% mark, it will say it stopped unexpectedly. No errors in the logs. I tried to uninstall it and reinstall and run it but when it is syncing, it always show the same error
I had something similar happen. In my case, my Intel NUC overheated (thermal shutdown) around 5-10% and rebooted, which corrupted the Initial Block Download (715 GB). Once it corrupted, I had to start over from scratch. After this happened 3X’s, I ended up having to disable Intel Turbo Boost in the BIOS, and it fixed my problem.
