Bitcoin node is stuck "starting..."
Hello, after my Bitcoin node was almost finished syncing the blockchain, it became stuck and it wont start.
Things i have already done:
  • starting the debug script (Result: “The debug script did not automatically detect any issues with your Umbrel.”)
  • removing settings.json and peers.dat by using:
    sudo rm ./umbrel/app-data/bitcoin/data/bitcoin/settings.json
    sudo rm ./umbrel/app-data/bitcoin/data/bitcoin/peers.dat
Unfortunately it is still stuck. Do you have any ideas?
Does nobody have any idea? It is still stuck starting :smile:
It is now stuck on the home screen. I am know kinda fed up with umbrel. Do you know any alternatives? Citadel? Raspiblitz?
How much storage capacity and RAM do you have available?
I am running umbrel in a Proxmox VM:
  • 4 CPU Cores
  • 6GB RAM
  • 640GB SSD
  • Ubuntu 22.04 LTS
Could it be that there is too little SSD storage? But there are still around 30GB unused.
Yes, I think storage capacity and memory might be the issue. I run a ligtning node with only the basic apps, and I am currently using 658.4 GB of storage. I have 8GB RAM and could definitely use more.
I could bumb it up to 7,5 GB RAM and 800GB of SSD. Maybe that will work.
Maybe it would work for a while, but the blockchain is growing. 1TB is recommended on Umbrel’s page when installing on a RasPi, and I guess that would apply for other setups as well. For my next node I want 2TB SSD and 16GB RAM :smiley:
Having same problem…
Same issue. Last week all was working great… Did you solve it?
Canot believe this is a resource issue…
Nope. Unfortunately I killed the whole system by trying to repartition the SSD. I am just a beginner in Linux :sweat_smile: But I also don’t think that it is a resource problem either. I think have set it up again with 7GB RAM and 900GB SSD which should be enough I think.
Hmm shit :sweat_smile:
Ok, I will probably dig deeper in the coming days, will update here if I find smt
Electrs says waiting for node to finish sync, strange… It should be synced.
Need to login via ssh and read some logs probably
Fixed it:
  1. login ssh
  2. docker ps
  3. search for ID of image “getumbrel/bitcoind:v24.0.1”
  4. docker logs $ID
This showed me smt regarding a corrupted file peers.dat…
To fix it, I did this two commands:
$ mv /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/peers.dat /mnt/data/umbrel/app-data/bitcoin/data/bitcoin/peers.dat.backup
and
$ mv /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/peers.dat /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/peers.dat.backup
Then restarted umbrel via UI.
Perfectly fixed with your instructions, thank you 0x188181818
I have similar issue now after my upgrade of Lightning node to v0.16.2-beta.
Can I just need copy of your 2 commands after ssh into my umbrel or should I need to customize anything?
Thank you.
