Bitcoin runs well, after a time it stops
Hi, can somebody help pls…?
I bought a new Raspberry PI 5 with 8G RAM
Prepared and installed Umbrel on a 32GB card
Connected a new 2TB SSD card to the Raspi
when system is up and running, installed Bitcoin. Bitcoin starts running, but suddenly stops.
I tried different Umbrel versions, all with same neg. effect.
No interrupt on Network (up/down 100MB) nor on power supply
here is the log:
bitcoin_server_1 | umbrel-middleware
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z init message: Verifying blocks…
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verifying last 6 blocks at level 3
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 0%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 16%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 33%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 50%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 66%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 83%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification progress: 99%
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Verification: No coin database inconsistencies in last 6 blocks (909 transactions)
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z block index 7355ms
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Opening LevelDB in /data/.bitcoin/indexes/txindex
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Opened LevelDB successfully
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Using obfuscation key for /data/.bitcoin/indexes/txindex: 0000000000000000
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Opening LevelDB in /data/.bitcoin/indexes/blockfilter/basic/db
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Using obfuscation key for /data/.bitcoin/indexes/blockfilter/basic/db: 0000000000000000
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Setting NODE_NETWORK on non-prune mode
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z block tree size = 895204
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z nBestHeight = 209067
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z initload thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Bound to 0.0.0.0:8333
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Bound to 10.21.21.8:8334
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Loaded 0 addresses from “anchors.dat”
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z 0 block-relay-only anchors will be tried for connections.
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z init message: Starting network threads…
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z net thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z [error] A fatal internal error occurred, see debug.log for details: Corrupt block found indicating potential hardware failure.
bitcoin_bitcoind_1 | Error: A fatal internal error occurred, see debug.log for details: Corrupt block found indicating potential hardware failure.
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z [error] ConnectTip: ConnectBlock 000000000000026a273aee1decf66078210dafe9cb3d38d8455a000bf840a512 failed, bad-txnmrklroot, hashMerkleRoot mismatch
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z [error] A fatal internal error occurred, see debug.log for details: Failed to connect best block (bad-txnmrklroot, hashMerkleRoot mismatch).
bitcoin_bitcoind_1 | Error: A fatal internal error occurred, see debug.log for details: Failed to connect best block (bad-txnmrklroot, hashMerkleRoot mismatch).
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z txindex thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z txindex is enabled at height 209067
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z txindex thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Loading 0 mempool transactions from file…
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Imported mempool transactions from file: 0 succeeded, 0 failed, 0 expired, 0 already there, 0 waiting for initial broadcast
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z opencon thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z dnsseed thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Waiting 300 seconds before querying DNS seeds.
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z initload thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z msghand thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z addcon thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z basic block filter index thread start
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z basic block filter index is enabled at height 209067
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z basic block filter index thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z init message: Done loading
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Shutdown: In progress…
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z dnsseed thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z opencon thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z addcon thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z net thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z msghand thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z DumpAnchors: Flush 0 outbound block-relay-only peer addresses to anchors.dat started
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z DumpAnchors: Flush 0 outbound block-relay-only peer addresses to anchors.dat completed (0.00s)
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z scheduler thread exit
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Flushed fee estimates to fee_estimates.dat.
bitcoin_bitcoind_1 | 2025-05-04T13:41:46Z Shutdown: done
