After update to umbrel 1.2 Bitcoin core and Electrs not starting anymore
umbrel@umbrel:~$ umbreld client apps.restart.mutate --appId bitcoin
TRPCClientError: Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script start bitcoin
    at TRPCClientError.from (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/TRPCClientError-38f9a32a.mjs:27:20)
    at file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/links/httpLink.mjs:35:60
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
  meta: {
    response: Response {
      [Symbol(realm)]: null,
      [Symbol(state)]: [Object],
      [Symbol(headers)]: [HeadersList]
    responseJSON: { error: [Object] }
  shape: {
    message: 'Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script start bitcoin',
    code: -32603,
    data: {
      code: 'INTERNAL_SERVER_ERROR',
      httpStatus: 500,
      stack: 'Error: Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script start bitcoin\n' +
        '    at makeError (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/lib/error.js:60:11)\n' +
        '    at handlePromise (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/index.js:124:26)\n' +
        '    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n' +
        '    at App.restart (/usr/local/lib/node_modules/umbreld/source/modules/apps/app.ts:217:3)\n' +
        '    at async resolveMiddleware (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:421:30)\n' +
        '    at async callRecursive (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:451:32)\n' +
        '    at async resolve (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:481:24)\n' +
        '    at async inputToProcedureCall (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/resolveHTTPResponse-2fc435bb.mjs:46:22)',
      path: 'apps.restart',
      zodError: null
  data: {
    httpStatus: 500,
    zodError: null
  [cause]: undefined
Does anyone know how to fix this?
