I’m having some underlying hardware issues with my Raspberry Pi. I usually try to do troubleshooting through Umbrel but it does not have rights privileges and I need those to fix this problem. Would anyone be able to point me to a walk through of how I could directly access and interface with my Ras Pi? (Keyboard/monitor or some other way)?
Does SSH not do what you need it to?
You have a couple options here you do have the option of physically connecting keyboard and monitor to your pi I found a video covering that
But I think the option your probably looking for is ssh.
You would go to either powershell or terminal on another computer on your network and enter
ssh umbrel@umbrel.local
If you know your Umbrel’s ip address you can use that in place of Umbrel.local aswell.
