I’ve setup a new Raspberry Pi 4. I booted up and installed NOOBS and flashed Umbrel onto an my SD card. I was able to set up my Umbrel account by accessing umbrel.local after booting my node up and am currently syncing the BTC blockchain.
But I can’t get into my Raspberry Pi anymore since flashing Umbrel onto the SD card. It runs a bunch of commands when I boot it up and then asks for my login and password (which I never made). Problem is that it also will not let me type/won’t recognize that I have a keyboard and mouse plugged into my Pi. This is not a hardware issue because I previously used the Pi and set up everything with a plugged in Keyboard and Mouse.
How do I get past this screen? I’ve already tried reflashing Umbrel over three times with no luck.
