Acceso a Umbrel para conectar via wifi
Hello. A few weeks ago I installed Umbrel and Bitcoin Node on a PC via network cable. Today, I logged in again to configure the wifi connection but it asks me for a username and password. When I installed Umbrel I don’t remember having configured any username or password.
First problem: any solution to access the Umbrel terminal, with a default username or password or any other way to recover the access credentials without having to re-synchronize the Bitcoin Blockchain again?
Second problem: how to configure Umbrel to connect via wifi.
Thanks.
Once you get into your node, the GUI covers it. In the top right corner is a Wi-Fi symbol, which you can click to open it. Select the network and put in the password.
