I’m trying to withdraw sats from LN Markets. I can easily deposit sats, but withdrawing results in a Lightning Network Invoice (LNMarkets Withdraw - Unpaid Invoice). I do not have a external wallet. I believe withdrawing should be possible as easy as depositing?
To withdraw is simple: go to your Umbrel node (RTL/Thunderhub) and from your LN wallet create a LN invoice with the amount you want to withdraw. Then go to Lnmarket and past it. Done
Thanks for your reply. Next issue to iron out while trying your solution: “There is no route for your payment”. A channel is up and running though (and funded).
Yes, I concur. But just to be certain, indeed I have one channel (balanced) 300/k/200k sats. Do I understand correctly that this cannot work hence I need more then one channel?
