Rspi4
Lan
Laptop
Umbrel 4.17 (looked up version using linux)
Fresh sd
Router with indicate rspi named umbrel and always same ip
Problem: I can’t login to umbrel now for 3 months. I have no backup.
If I try to ssh into umbrel I get response:
“port 22: Connection timed out”"
What now?
I read all the trouble shoot pages.
Hey @Mikel357! Sorry for the delay,
It’d be nice to have more details about the error, you can get those details using:
ssh -vvv umbrel@umbrel.local
and provide all the logs using pastebin.com
It may be even worth checking if you can ssh to your umbrel using another device in that case you can try to remove the known_host file on your windows machine
rm .\.ssh\known_host
Thanks dude but please read my post, I can’t ssh in!
Tell me how!
If you try to ssh with the -vvv parameters it’ll provide all the logs about how and why it can’t connect
you can then provide all the logs using pastebin.com
Maybe we’ll find what’s the issue in these logs
Same shit…port 22 blah blah blah
Alright ! It looks like ssh can’t read the .ssh/config file, you may want to try running the terminal in administrator mode to see if it fixes the problem you can run both :
ssh -vvv umbrel@192.168.1.197
Hey @Mikel357 ! Sorry for the delay,
It’d be worth checking if you can ssh via another device, you can try ssh’ing using the Termiux app on your phone.
ssh -t umbrel@umbrel.local
ssh -t umbrel@192.168.1.197
If both don’t work, it’s probably an issue with your RaspberryPi or mSD card.
