Hi, i am saif mahammed, i am running my umbrelos the very latest one on my raspberry pi 4 with 8 gigs of ram and also with 256 gigs of storage micro sd card. I can access my stuff from my dashboard umbrel.local but i have setup nothing. I have tried to ssh into it its ip is this:
192.168.10.36 and i have flashed the sd card for about 10 times till now. I am trying to do using all the stuff there is used termius still getting the same error as a Terminal or Iterm on mac. this is the error:
π€ Starting a new connection to: "192.168.10.36" port "22"
βοΈ Starting address resolution of "192.168.10.36"
βοΈ Address resolution finished
βοΈ Connecting to "192.168.10.36" port "22"
π€ Connection to "192.168.10.36" established
βοΈ Starting SSH session
βοΈ Remote server: SSH-2.0-OpenSSH_9.2p1 Debian-2+deb12u3
βοΈ Agreed KEX algorithm: curve25519-sha256
βοΈ Agreed Host Key algorithm: ecdsa-sha2-nistp256
βοΈ Agreed server-to-client cipher: aes256-gcm@openssh.com MAC: INTEGRATED-AES-GCM
βοΈ Agreed client-to-server cipher: aes256-gcm@openssh.com MAC: INTEGRATED-AES-GCM
βοΈ Agreed client-to-server compression: none
βοΈ Agreed server-to-client compression: none
βοΈ Handshake finished
π€ Checking host key: d5:0d:bb:2a:27:79:97:ce:76:8e:25:c5:57:a0:b3:9f
π€ Host "192.168.10.36":"22" is known and matches
π€ Authenticating to "192.168.10.36":"22" as "umbrel"
β Disabling authentication using publickey: Private Key is empty
βοΈ Available client authentication methods: password,keyboard-interactive
βοΈ Authentication that can continue: publickey,password
π€ Authenticating using password method
β Authentication failed (password)
βοΈ Partial success: no
π¨ No more authentication methods to try
Blockquote
Do any one have any answer to this thing?
Help me to fix it i guess the default username and password are `
umbrel and moneyprintergobrrr
Thank You in advance for spending your time and answering in advance!
