After a reset my wallet amount keeps showing a grey field. Blockchain is in sync for,100%
Any thoughts as reset will not do the trick.
@V3n0m be patient and wait for the sync to complete!
If that QR code it doesn’t show the address, means your wallet is locked or something else is happening.
A simple wrong line in your lnd.conf or even wrong color code you put, it can stale the starting of your node.
Review the troubleshooting manual, but first run the debug logs to see what is hapenning.
Also a similar situation was fixed here
