Bitcoin Address Blank
My node doesn’t show the BTC I sent to it from another Umbrel node a month ago. Everything seems to be working except the BTC wallet has no address and after clicking the deposit button once, it won’t respond after.
I’ve rebooted, and tried every other troubleshooting tip I could find.
I would appreciate any suggestions.
Same thing and same non-valid QR code (pixel perfect copy)
Not sure, but after a reboot there was a long gap between blocks and problem was still there. A new block came in, and I got my addy back. Problem solved, but not sure how.
Same. Reboot seemed to fix the issue and all sats are accounted for.
I am having the same issue. How did you reboot exactly? just shut down and start back up? Or did you hit the restart option? Did you re-flash the SD card?
