Most likely it’s the initial indexing for the faster file search, new Photos app, etc. keeping the CPU busy after the upgrade. I’d give it a couple of hours to finish, though it could take longer if you have lots of files. Temperatures should hopefully settle back down once that’s done.
If it’s still running that hot after that, checking what’s using the CPU in top, as suggested above, would be a good next step.
