If you run umbrelOS on a 2018 Mac mini (T2 chip), it’s probably sitting in the 80s–90s °C and throttling constantly, even at idle. Linux can’t see the T2’s fan, and Apple’s firmware lets the CPU turbo as if macOS were there to spin the fan up.
I wrote a small tool that fixes it by stopping the turbo sprints and capping CPU power. It needs no kernel patches, it backs up your settings first, and revert puts everything back. On my node (Bitcoin + Lightning):
- Throttle events went from ~440/min to 0 over 12 days
- Median temperature 58°C (it used to peak at 100°C)
- The node itself runs exactly the same; these workloads don’t need turbo
It survives umbrelOS updates (the README has an umbrelOS section): GitHub - Tomcatt/t2chill: Keep a T2 Mac mini (2018) cool under Linux with no kernel patches: stops turbo sprints and caps CPU power. Backup-first, fully reversible. · GitHub
It’s only been tested on a Macmini8,1 so far, so reports from other T2 Macs are welcome.
