Anyone else at 100% usage and just running a few apps?
Lightning node is sitting around 55-65% usage and system at ~30%
Hoping there is a work around/fix for this soon, cant be running at 100% for long and over heating my node (even in a cold basement with a fan)
Running UmbrelOS 1.1
CPU usage may not be 100% accurate on the dashboard right now- we’re working on improving this.
For a more detailed insight, you can use these steps:
Navigate to the Settings (http:umbrel.local/settings) > Advanced Settings > Terminal > umbrelOS.
Run command top you may need to scroll up a little
I installed umbrelOS 1.1.2 on a miniPC N4000/4GB/7TB from a bootable stick as advised at GitHub - getumbrel/umbrel: A beautiful home server OS for self-hosting with an app store. Buy a pre-built Umbrel Home with umbrelOS, or install on a Raspberry Pi 4, Pi 5, any Ubuntu/Debian system, or a VPS. without problem.
After installing bitcoin node it run pretty well with internet speed 500 MB. being happy I added Seafile next day and tried to open: the system became extremely slow and inresponsive. Dashboard stopped, after closing we page using local link and its reopening - endless circling. No access from the terminal - it does not accept the password, no response … What options exist in such situation?
Wait days? Power off/on? Reinstall?
Any advise from Umbrel team or folks?
I actually ended up restarting, it pushed an update and now usage has dropped to ~4% which seems right lol
After migrating from Umbrel 0.5.4 to 1.1.2 I get 100% CPU load most of the time.
top - 13:51:12 up 4:50, 2 users, load average: 1.61, 0.93, 0.77
Tasks: 265 total, 3 running, 262 sleeping, 0 stopped, 0 zombie
%Cpu(s): 44.5 us, 25.6 sy, 0.0 ni, 28.6 id, 0.0 wa, 0.0 hi, 1.3 si, 0.0 st
MiB Mem : 7874.9 total, 298.4 free, 5374.1 used, 2511.9 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 2500.8 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
4139 root 20 0 61.1g 135428 17972 R 87.5 1.7 8:43.53 node
9965 umbrel 20 0 3642148 969564 127244 S 11.2 12.0 19:54.61 bitcoind
9818 umbrel 20 0 1615440 572996 2552 S 8.3 7.1 18:29.71 electrs
9208 umbrel 20 0 63212 37512 3988 S 3.6 0.5 2:06.49 tor
466 root 20 0 3002084 104796 23300 S 3.3 1.3 3:19.55 dockerd
9188 umbrel 20 0 2220796 510696 161184 S 2.0 6.3 3:38.07 lnd
Notice the 61.1 GB virtmem! Seems there is a memory leak.
This comes from the node.io module but no idea what it actually does:
root@umbrel:/home/umbrel# ps -ef | grep 4139
root 4139 3926 3 09:01 ? 00:08:53 /usr/bin/node --require /usr/local/lib/node_modules/umbreld/node_modules/tsx/dist/preflight.cjs --import file:///usr/local/lib/node_modules/umbreld/node_modules/tsx/dist/loader.mjs /usr/local/lib/node_modules/umbreld/./source/cli.ts --data-directory=/home/umbrel/umbrel --log-level verbose
root 4179 4139 0 09:01 ? 00:00:11 /usr/local/lib/node_modules/umbreld/node_modules/@esbuild/linux-x64/bin/esbuild --service=0.20.2 --ping
After further investigation it seems to be related to the 3-in-1 “Live usage” CPU/Mem/Storage widget. If I disable it from the start page, CPU goes down to normal values.
on my pi 4, I was running close to 100% on v1.1 all the time. I just upgraded to v1.2 and it’s fluctuating from 40 ish up to 100. It’s better but something seems off still. mem usage went down with the update though.
3863 umbrel 20 0 4012076 911164 209448 S 92.4 11.4 34:24.89 bitcoind
11705 umbrel 20 0 2553924 840404 10624 R 56.1 10.5 8:28.46 node
umbrel 11705 11602 18 04:23 ? 00:08:11 node /backend/package/index.js
zyyypp
August 25, 2024, 9:39pm
7
I have the same issue here… node process is eating one core on RPI4 more less all the time. I am on latest version 1.2.2
