I’ve tried to upgrade my umbrel from 4.15 to 4.16. Unfortunately I cant log in anymore after that.
Right now web interface says “upgrading installed apps”.
Can login via ssh (although it seems very slow - although it might be just my lan network - I’m using some “internet over power cables” adaptors).
I’ve reached out for help in telegram group and were able (thanks to @Indomitorum) to start lnd and other services, waited for it to update the chainstate but once finished it wasn’t showing my balance (bitcoin-cli getbalance) and showed some sats in lncli walletbalance (but not sure if the right amount since it’s been a while since it died so I’m not sure if its right…).
After that we decided it might be broken container - so I’ve done:
sudo scripts/stop
sudo rm .env && sudo ./scripts/configure
sudo reboot
sudo scripts/start
After reboot I still cannot access web interface - and lnd log says wallet locked (even after doing lncli unlock):
tail -f lnd/logs/bitcoin/mainnet/lnd.log
Blockquote
2022-03-25 21:51:51.354 [INF] LTND: Creating local graph and channel state DB instances
2022-03-25 21:51:55.280 [INF] CHDB: Checking for schema update: latest_version=24, db_version=24
2022-03-25 21:51:55.281 [INF] LTND: Database(s) now open (time_to_open=6.316880626s)!
2022-03-25 21:51:55.281 [INF] LTND: We’re not running within systemd
2022-03-25 21:51:55.281 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
2022-03-25 21:51:59.476 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:51:59.476 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:51:59.477 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:51:59.477 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:04.739 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
q2022-03-25 21:52:19.662 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:19.662 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:19.663 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:19.663 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:19.771 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:31.061 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:31.062 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:31.062 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:34.789 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:40.940 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:40.940 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:40.940 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:45.617 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:45.690 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:52:48.942 [INF] LNWL: Opened wallet
2022-03-25 21:52:49.379 [INF] CHRE: Primary chain is set to: bitcoin
2022-03-25 21:52:49.646 [ERR] LTND: unable to create partial chain control: status code: 401, response: “”
2022-03-25 21:52:49.647 [ERR] LTND: Shutting down because error in main method: error creating wallet config: unable to create partial chain control: status code: 401, response: “”
2022-03-25 21:52:53.065 [INF] LTND: Version: 0.14.2-beta commit=v0.14.2-beta, build=production, logging=default, debuglevel=info
2022-03-25 21:52:53.066 [INF] LTND: Active chain: Bitcoin (network=mainnet)
2022-03-25 21:52:53.068 [INF] RPCS: RPC server listening on 0.0.0.0:10009
2022-03-25 21:52:53.072 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
2022-03-25 21:52:53.073 [INF] LTND: Opening the main database, this might take a few minutes…
2022-03-25 21:52:53.073 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
2022-03-25 21:52:54.191 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
2022-03-25 21:52:55.498 [INF] LTND: Creating local graph and channel state DB instances
2022-03-25 21:52:59.115 [INF] CHDB: Checking for schema update: latest_version=24, db_version=24
2022-03-25 21:52:59.115 [INF] LTND: Database(s) now open (time_to_open=6.041924995s)!
2022-03-25 21:52:59.116 [INF] LTND: We’re not running within systemd
2022-03-25 21:52:59.116 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
2022-03-25 21:53:03.392 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:03.393 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:03.392 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:03.393 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:04.846 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:13.530 [ERR] RPCS: [/lnrpc.Lightning/SubscribeInvoices]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:13.530 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
2022-03-25 21:53:13.530 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access`
Blockquote
My debug log:
https://0bin.net/paste/LQaO1xtJ#J8uNYkh4LyqXuYpMsNuFSqxpPNBg1HeIFn14xT7I2j+
What should I attempt next to revive it?
Thanks
