as title says looking to upgrade from rasp pi 4, would a beelink Pro be a good option and is it easy to setup/migrate? Thanks
I don’t know about the Beelink Pro but I know an X86 is easy to setup. I would recommend using a 4 TB m.2 SSD for the node. I know once I moved to the x86 machine, the external drive was no longer needed.
