Hi sorry for another system service failed but i’ve read the debug and can’t pinpoint the pb. Before Umbrel crashed completly it gave me an sd card failure notice so i changed it but still can access Umbrel.
My setup is a raspberry pi 4b 8GB RAM 2TB SSD 32GB micro SD official power cable.
Here is the debug:
C:\Users\asari>ssh -t umbrel@umbrel.local “~/umbrel/scripts/debug”
umbrel@umbrel.local’s password:
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03115
Serial : 100000002e3664d9
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=39.4’C
Throttling
throttled=0x0
Mem: 7.8G 103M 7.5G 8.0M 231M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.3%
system: 1.3%
Memory monitor logs
2024-01-13 12:04:13 Memory monitor running!
2024-01-15 15:07:52 Memory monitor running!
2024-01-22 06:54:32 Memory monitor running!
2024-01-22 13:15:26 Memory monitor running!
2024-01-24 06:56:46 Memory monitor running!
2024-01-24 07:33:52 Memory monitor running!
/dev/root 30G 3.5G 25G 13% /
/dev/sda1 3.6T 714G 2.8T 21% /home/umbrel/umbrel
Startup service logs
– Logs begin at Thu 2024-01-25 22:22:14 UTC, end at Thu 2024-01-25 22:23:32 UTC. –
Jan 25 22:23:06 umbrel systemd[1]: Starting Umbrel Startup Service…
Jan 25 22:23:06 umbrel umbrel startup[1095]: parse error: Unfinished string at EOF at line 1, column 1044
Jan 25 22:23:06 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=4/NOPERMISSION
Jan 25 22:23:06 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jan 25 22:23:06 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jan 25 22:23:17 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jan 25 22:23:17 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 1.
Jan 25 22:23:17 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jan 25 22:23:17 umbrel systemd[1]: Starting Umbrel Startup Service…
Jan 25 22:23:17 umbrel umbrel startup[1372]: parse error: Unfinished string at EOF at line 1, column 1044
Jan 25 22:23:17 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=4/NOPERMISSION
Jan 25 22:23:17 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jan 25 22:23:17 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jan 25 22:23:27 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jan 25 22:23:27 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 2.
Jan 25 22:23:27 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jan 25 22:23:27 umbrel systemd[1]: Starting Umbrel Startup Service…
Jan 25 22:23:27 umbrel umbrel startup[1453]: parse error: Unfinished string at EOF at line 1, column 1044
Jan 25 22:23:27 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=4/NOPERMISSION
Jan 25 22:23:27 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jan 25 22:23:27 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
Jan 25 22:22:19 umbrel external storage mounter[506]: Found device “WD Elements 2621”
Jan 25 22:22:19 umbrel external storage mounter[506]: Blacklisting USB device IDs against UAS driver…
Jan 25 22:22:19 umbrel external storage mounter[506]: Rebinding USB drivers…
Jan 25 22:22:19 umbrel external storage mounter[506]: Checking USB devices are back…
Jan 25 22:22:19 umbrel external storage mounter[506]: Waiting for USB devices…
Jan 25 22:22:20 umbrel external storage mounter[506]: Waiting for USB devices…
Jan 25 22:22:21 umbrel external storage mounter[506]: Waiting for USB devices…
Jan 25 22:22:22 umbrel external storage mounter[506]: Checking if the device is ext4…
Jan 25 22:22:22 umbrel external storage mounter[506]: Yes, it is ext4
Jan 25 22:22:22 umbrel external storage mounter[506]: Checking filesystem for corruption…
Jan 25 22:22:22 umbrel external storage mounter[506]: e2fsck 1.44.5 (15-Dec-2018)
Jan 25 22:22:25 umbrel external storage mounter[506]: umbrel: recovering journal
Jan 25 22:22:30 umbrel external storage mounter[506]: umbrel: clean, 296167/244187136 files, 202566242/976745728 blocks
Jan 25 22:22:30 umbrel external storage mounter[506]: Mounting partition…
Jan 25 22:22:30 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
Jan 25 22:22:30 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
Jan 25 22:22:30 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
Jan 25 22:22:30 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
Jan 25 22:22:30 umbrel external storage mounter[506]: Bind mounting external storage to /swap
Jan 25 22:22:30 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
Jan 25 22:22:30 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
Jan 25 22:22:31 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
Jan 25 22:22:31 umbrel external storage mounter[506]: Checking /swap is now on external storage…
Jan 25 22:22:31 umbrel external storage mounter[506]: Setting up swapfile
Jan 25 22:22:44 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jan 25 22:22:44 umbrel external storage mounter[506]: no label, UUID=ebb232dc-eb47-429d-abf7-77190ad95bdc
Jan 25 22:22:44 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
Jan 25 22:22:44 umbrel external storage mounter[506]: Starting external drive mount monitor…
Jan 25 22:22:44 umbrel external storage mounter[506]: Mount script completed successfully!
Jan 25 22:22:44 umbrel systemd[1]: Started External Storage Mounter.
Jan 25 22:23:06 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jan 25 22:23:06 umbrel external storage updater[1016]: Checking if SD card Umbrel is newer than external storage…
Jan 25 22:23:06 umbrel external storage updater[1016]: No, SD version is not newer, exiting.
Jan 25 22:23:06 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Pulling api … extracting (42.1%)
Pulling api … extracting (47.7%)
Pulling api … extracting (51.9%)
Pulling api … extracting (57.5%)
Pulling api … extracting (64.5%)
Pulling api … extracting (74.3%)
Pulling api … extracting (79.9%)
Pulling api … extracting (91.1%)
Pulling api … extracting (96.7%)
Pulling api … extracting (100.0%)
Pulling api … pull complete
Pulling api … extracting (1.1%)
Pulling api … extracting (5.3%)
Pulling api … extracting (9.5%)
Pulling api … extracting (12.6%)
Pulling api … extracting (17.9%)
Pulling api … extracting (23.1%)
Pulling api … extracting (29.4%)
Pulling api … extracting (35.7%)
Pulling api … extracting (42.0%)
Pulling api … extracting (47.3%)
Pulling api … extracting (52.6%)
Pulling api … extracting (56.8%)
Pulling api … extracting (61.0%)
Pulling api … extracting (65.2%)
Pulling api … extracting (69.4%)
Pulling api … extracting (73.6%)
Pulling api … extracting (76.7%)
Pulling api … extracting (83.0%)
Pulling api … extracting (86.2%)
Pulling api … extracting (89.3%)
Pulling api … extracting (92.5%)
Pulling api … extracting (95.7%)
Pulling api … extracting (98.8%)
Pulling api … digest: sha256:c58996a3bfd382cb78…
Pulling api … status: downloaded newer image fo…
Pulling api … done
Starting app mempool…
Creating mempool_app_proxy_1 …
Creating mempool_api_1 …
Creating mempool_tor_server_1 …
Creating mempool_web_1 …
Creating mempool_mariadb_1 …
Docker containers
Umbrel logs
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 802, in urlopen
**response_kw,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 504, in _make_request
enforce_content_length=enforce_content_length,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connection.py”, line 395, in request
self.endheaders()
File “/usr/lib/python3.7/http/client.py”, line 1259, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1034, in _send_output
self.send(msg)
File “/usr/lib/python3.7/http/client.py”, line 974, in send
self.connect()
File “/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py”, line 27, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.7/dist-packages/requests/adapters.py”, line 497, in send
chunked=chunked,
File “/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py”, line 845, in urlopen
method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.7/dist-packages/urllib3/util/retry.py”, line 470, in increment
raise reraise(type(error), error, _stacktrace)
File “/usr/local/lib/python3.7/dist-packages/urllib3/util/util.py”, line 38, in reraise
raise value.with_traceback(tb)
**response_kw,
self.endheaders()
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 602, in get
return self.request(“GET”, url, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/requests/adapters.py”, line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/bin/docker-compose”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 200, in perform_command
project = project_from_options(‘.’, options)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 70, in project_from_options
enabled_profiles=get_profiles_from_options(options, environment)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 153, in get_project
verbose=verbose, version=api_version, context=context, environment=environment
File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 43, in get_client
environment=environment, tls_version=get_tls_version(environment)
File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 197, in init
self._version = self._retrieve_server_version()
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 222, in _retrieve_server_version
f’Error while fetching server API version: {e}’
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Tor Proxy logs
**response_kw,
self.endheaders()
self.send(msg)
self.connect()
chunked=chunked,
**response_kw,
self.endheaders()
self.send(msg)
self.connect()
sys.exit(main())
command_func()
==== Result ====
==== END =====
Thanks for you help
