I have a Raspberry Pi that was working perfectly fine until just now.
I downloaded the new OS 1.0, flashed my Micro SD Card as I did with previous versions but when booting up it gets stuck forever in a loop… I’m very worried because I can’t make it boot now. Any idea?
below some of the messages I get on screen
systend- journaldf1491: /var/log/ journal/a220d67e3fa94c3bb602315fb3Bed54a/system.journal: Journal header limits reached or header out-of-d
EXT-fs (sdal): mounted filesystem 32930a28-b91a-14a2-6124-5beb0116a333 r/w with ordered data mode. Quota mode: none.
53.1879671 Adding 4194300k swap on /swap/Swapfile. Priority:-2 extents:322 across:598925312k
61.7473071
bridge: filtering via arp/ip/ipotables is no longer available by default. Update your scripts to load br_netfilter if you need this.
64.7552841 Bridge firewalling registered
65.1293441 Initializing XFRM netlink socket
LTIII
71.405187] br-61693631978: port 1(vethd115697) entered blocking state
71.405291] br-6f69363197eB: port 1(vethd115697) entered disabled state
71.405382] vethd115697: entered allmulticast mode
71.4056581 vethd115697: entered promiscuous mode
72.166237] br-6/693631978: port 2(vethae122f) entered blocking state
72.166338] br-6f693631978: port 2(uethae122fd) entered disabled state
72.166477] vethae122fd: entered allnulticast mode
72.168331] vethae122fd: entered proniscuous mode
72.172308] br-6669363197eB: port 2(vethae122fd) entered blocking state
72.172411] br-6f693631978: port 2(vethae122fd) entered forwarding state
72.174844] br-6f693631978: port 2(vethae122fd) entered disabled state
72.457367] br-6f69363197e8: port 3(vethc740f09) entered blocking state
72.457459] br-6f693631978: port 3(vethc740f09) entered disabled state
72.457547] vethc?40f09: entered allmulticast mode
72.158098]
vethc740f09: entered promiscuous mode
72.459321] br-66693631978: port 3(vethc?40f09) entered blocking state
72.459409] br-6f693631978: port 3(vethc740f09) entered forwarding state
72.463211] br-6f693631978: port 3(vethc740f09) entered disabled state
