Hello, I just got a brand new RPi4 and loaded the iso on the sd, it starts up then it gets stuck at the “Daily apt upgrade and clean activities”. I pulled up the debug logs, apologies in advance if I missed this problem somewhere on the forum. Thanks
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03115
Serial : 100000002086ec0d
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=42.3’C
Throttling
throttled=0x0
Mem: 7.8G 353M 6.4G 16M 1.0G 7.3G
Swap: 4.1G 0B 4.1G
total: 4.5%
system: 4.5%
Memory monitor logs
2023-06-22 16:45:30 Memory monitor running!
2023-08-24 04:56:52 Memory monitor running!
/dev/root 118G 3.2G 110G 3% /
/dev/sda1 220G 5.4G 203G 3% /home/umbrel/umbrel
Startup service logs
Aug 24 04:56:52 umbrel systemd[1]: Starting Umbrel Startup Service…
Aug 24 04:56:52 umbrel umbrel startup[1815]: ======================================
Aug 24 04:56:52 umbrel umbrel startup[1815]: ============= STARTING ===============
Aug 24 04:56:52 umbrel umbrel startup[1815]: ============== UMBREL ================
Aug 24 04:56:52 umbrel umbrel startup[1815]: Setting environment variables…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting karen…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting status monitors…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting memory monitor…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting backup monitor…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting decoy backup trigger…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting umbreld…
Aug 24 04:56:52 umbrel umbrel startup[1815]: Starting Docker services…
Aug 24 04:56:55 umbrel umbrel startup[1815]: Creating manager …
Aug 24 04:56:55 umbrel umbrel startup[1815]: Creating auth …
Aug 24 04:56:55 umbrel umbrel startup[1815]: Creating dashboard …
Aug 24 04:56:55 umbrel umbrel startup[1815]: Creating tor_proxy …
Aug 24 04:56:57 umbrel umbrel startup[1815]: Creating tor_proxy … done
Aug 24 04:56:57 umbrel umbrel startup[1815]: Creating manager … done
Aug 24 04:56:58 umbrel umbrel startup[1815]: Creating dashboard … done
Aug 24 04:56:58 umbrel umbrel startup[1815]: Creating nginx …
Aug 24 04:56:58 umbrel umbrel startup[1815]: Creating auth … done
Aug 24 04:56:59 umbrel umbrel startup[1815]: Creating nginx … done
Aug 24 04:57:00 umbrel umbrel startup[1815]: Removing status server iptables entry…
Aug 24 04:57:00 umbrel umbrel startup[1815]: Removed existing iptables entry.
Aug 24 04:57:00 umbrel umbrel startup[1815]: Starting installed apps…
Aug 24 04:57:00 umbrel umbrel startup[1815]: Umbrel is now accessible at
Aug 24 04:57:00 umbrel umbrel startup[1815]: http://umbrel.local
Aug 24 04:57:00 umbrel umbrel startup[1815]: http://192.168.1.200
Aug 24 04:57:00 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Jun 22 16:44:07 umbrel external storage mounter[527]: Waiting for USB devices…
Jun 22 16:44:08 umbrel external storage mounter[527]: Waiting for USB devices…
Jun 22 16:44:09 umbrel external storage mounter[527]: Waiting for USB devices…
Jun 22 16:44:10 umbrel external storage mounter[527]: Checking if the device is ext4…
Jun 22 16:44:11 umbrel external storage mounter[527]: Yes, it is ext4
Jun 22 16:44:11 umbrel external storage mounter[527]: Checking filesystem for corruption…
Jun 22 16:44:11 umbrel external storage mounter[527]: e2fsck 1.44.5 (15-Dec-2018)
Jun 22 16:44:11 umbrel external storage mounter[527]: umbrel: recovering journal
Jun 22 16:44:13 umbrel external storage mounter[527]: Superblock last mount time is in the future.
Jun 22 16:44:13 umbrel external storage mounter[527]: (by less than a day, probably due to the hardware clock being incorrectly set)
Jun 22 16:44:13 umbrel external storage mounter[527]: Setting free inodes count to 14574209 (was 14655477)
Jun 22 16:44:13 umbrel external storage mounter[527]: Setting free blocks count to 56037503 (was 57411660)
Jun 22 16:44:13 umbrel external storage mounter[527]: umbrel: clean, 81279/14655488 files, 2571649/58609152 blocks
Jun 22 16:44:13 umbrel external storage mounter[527]: Mounting partition…
Jun 22 16:44:13 umbrel external storage mounter[527]: Checking if device contains an Umbrel install…
Jun 22 16:44:13 umbrel external storage mounter[527]: Yes, it contains an Umbrel install
Jun 22 16:44:13 umbrel external storage mounter[527]: Bind mounting external storage over local Umbrel installation…
Jun 22 16:44:13 umbrel external storage mounter[527]: Bind mounting external storage over local Docker data dir…
Jun 22 16:44:13 umbrel external storage mounter[527]: Bind mounting external storage to /swap
Jun 22 16:44:13 umbrel external storage mounter[527]: Bind mounting SD card root at /sd-card…
Jun 22 16:44:13 umbrel external storage mounter[527]: Checking Umbrel root is now on external storage…
Jun 22 16:44:15 umbrel external storage mounter[527]: Checking /var/lib/docker is now on external storage…
Jun 22 16:44:15 umbrel external storage mounter[527]: Checking /swap is now on external storage…
Jun 22 16:44:15 umbrel external storage mounter[527]: Setting up swapfile
Jun 22 16:44:15 umbrel external storage mounter[527]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 22 16:44:15 umbrel external storage mounter[527]: no label, UUID=3eb5edf1-06cb-4484-8285-b4e3296801a3
Jun 22 16:44:15 umbrel external storage mounter[527]: Checking SD Card root is bind mounted at /sd-root…
Jun 22 16:44:15 umbrel external storage mounter[527]: Starting external drive mount monitor…
Jun 22 16:44:15 umbrel external storage mounter[527]: Mount script completed successfully!
Jun 22 16:44:15 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2023-06-22 16:43:58 UTC, end at Thu 2023-08-24 05:31:24 UTC. –
Aug 24 04:56:52 umbrel systemd[1]: Starting External Storage SDcard Updater…
Aug 24 04:56:52 umbrel external storage updater[1737]: Checking if SD card Umbrel is newer than external storage…
Aug 24 04:56:52 umbrel external storage updater[1737]: No, SD version is not newer, exiting.
Aug 24 04:56:52 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal:
karen is getting triggered!
Got signal:
Got signal:
Got signal:
Docker containers
NAMES STATUS
nginx Up 34 minutes
tor_proxy Up 34 minutes
dashboard Up 34 minutes
auth Up 34 minutes
manager Up 34 minutes
Umbrel logs
Attaching to manager
manager | yarn run v1.22.18
manager | $ node ./bin/www
manager | Thu, 24 Aug 2023 04:57:03 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:49:9
manager | Thu, 24 Aug 2023 04:57:03 GMT morgan deprecated default format: use combined format at app.js:49:9
manager | Listening on port 3006
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Aug 24 04:57:10.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 24 04:57:10.000 [notice] Bootstrapped 61% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 24 04:57:11.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_proxy | Aug 24 04:57:11.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Aug 24 04:57:11.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Aug 24 04:57:11.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Aug 24 04:57:11.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Aug 24 04:57:12.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Aug 24 04:57:12.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Aug 24 04:57:12.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
==== END =====
