Unable to start storage on new installation
I’m trying UmbrelOS for the first time. I’ve set up a usb flash drive with Umbrel 2.0, and booted from it on a NUC which has a 4Tb SSD NVMe drive, currently in ext4 format. It boots ok, sees the drive, but gives the error message “umbrelOS couldn’t start your storage”. I’ve tried a couple of times, including doing a factory reset on umbrelos.
I’m not sure how to proceed. Should I just install umbrelOS directly to the 4Tb drive, or is there some other setting I should try?
Are you saying you flashed umbrel to a USB? If this is true, then yes, install it on the 4 TB drive and make that your boot drive.
