Gm Guys,
I started yesterday to set up my raspberry pi 5 with umbrel OS.
→ I followed the steps listed on the website (flashing umbrelOS on SD Card, connecting SSD, using the right components as official power supply)
→ I got this screen when booting (first image) with no bootable partition
→ So, I decided to try other methods :
1/ install first on SD Card, Raspberry OS, and from there, installing UmbrelOS with “curl -L https://umbrel.sh | bash”. It worked well, but I was not able to update my umbrelOS to 1.0 and also when I tried to install the bitcoin app, the app installed on the SD Card and not SSD so I have been blocked as the SD card is only 32 Go.
2/ I tried the same, but directly on SSD, with no SD Card. UmbrelOS have been installed (not 1.0) and the bitcoin App was not installing.
3/ I started back again from 0, and i still got the same error message while booting.
Can you help?
