What’s wrong with the software?
My Umbrel Node restarts over and over again itself. Sometimes after 6 days, sometimes after 2 hours…
I have a Pi5 8GB RAM with a 64GB Samsung SD-Card and a Samsung SSD 1TB
Sometimes it works for 20 days without problems, but suddenly it restarts itself without a logically reason.
I Use an USB-C Original Pi5 Power Supply.
Hi @piranhamix welcome to the community!
When was the last time your machine restarted? Is there any way you can capture a system log right after it crashes? They are so many things we might want to look through that logging is likely the only way to get started with that. If it has crashed recently could you capture a system log and share it with me. You can either post it in this thread, dm it to me, or dm me an encrypted version. If you are familiar with PGP my public key info is in my bio!
Otherwise maybe I could help you search through the logs. Let me know if you need help downloading your system’s log file!
