I am creating a post again since I did not receive help, my umbrel restarts every 24 hours (it does not restart, it turns off and the green light comes on on my raspberry pi) I already restarted it from 0, formatting the SD and the portable disk, without However, the shutdowns continue. My Node was at 50% (280GB) and when I turned it off and on again it went back to 37%
I don’t know what to do anymore, I had bitcoins on my Lightning node that I want to recover but I’m having a hard time installing the bitcoin node again because of the constant shutdowns it’s having, the power hasn’t gone out, the node doesn’t appear connected (check with AngryIP)
From the configurations there is 300GB in Bitcoin Node but in the app there are 270GB downloaded
I previously had my node 100% downloaded but one day what the title indicates happened, I had to unplug and plug back in and it required me to “reindex” and I did it, but nevertheless if it restarts every 24 hours it is impossible to do the reindex since it would go back to 0% every time (happened 5 times) until I decided to delete everything and try to download it again.
I am literally desperate, I am afraid that I have lost my money that I had in lightning node (not in channels, I only had bitcoin in my wallet)
Troubleshooting Log
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03115
Serial : 10000000e5491007
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=48.2’C
Throttling
throttled=0x0
Mem: 7.8G 901M 2.4G 17M 4.5G 6.8G
Swap: 4.1G 0B 4.1G
bitcoin: 13.6%
total: 11.5%
system: 0%
Memory monitor logs
2023-11-02 23:53:10 Memory monitor running!
2023-11-03 22:34:32 Memory monitor running!
2023-11-04 21:41:59 Memory monitor running!
/dev/root 119G 5.0G 109G 5% /
/dev/sda1 916G 287G 583G 33% /home/umbrel/umbrel
Startup service logs
Nov 04 21:41:59 umbrel umbrel startup[1808]: Starting Docker services…
Nov 04 21:42:04 umbrel umbrel startup[1808]: Creating manager …
Nov 04 21:42:04 umbrel umbrel startup[1808]: Creating auth …
Nov 04 21:42:04 umbrel umbrel startup[1808]: Creating tor_proxy …
Nov 04 21:42:04 umbrel umbrel startup[1808]: Creating dashboard …
Nov 04 21:42:12 umbrel umbrel startup[1808]: Creating tor_proxy … done
Nov 04 21:42:13 umbrel umbrel startup[1808]: Creating dashboard … done
Nov 04 21:42:13 umbrel umbrel startup[1808]: Creating manager … done
Nov 04 21:42:13 umbrel umbrel startup[1808]: Creating nginx …
Nov 04 21:42:15 umbrel umbrel startup[1808]: Creating auth … done
Nov 04 21:42:21 umbrel umbrel startup[1808]: Creating nginx … done
Nov 04 21:42:22 umbrel umbrel startup[1808]: Removing status server iptables entry…
Nov 04 21:42:22 umbrel umbrel startup[1808]: Removed existing iptables entry.
Nov 04 21:42:22 umbrel umbrel startup[1808]: Starting installed apps…
Nov 04 21:42:22 umbrel umbrel startup[1808]: Starting app bitcoin…
Nov 04 21:42:22 umbrel umbrel startup[1808]: Executing hook: /home/umbrel/umbrel/app-data/bitcoin/hooks/pre-start
Nov 04 21:42:25 umbrel umbrel startup[1808]: Creating bitcoin_tor_1 …
Nov 04 21:42:25 umbrel umbrel startup[1808]: Creating bitcoin_i2pd_daemon_1 …
Nov 04 21:42:25 umbrel umbrel startup[1808]: Creating bitcoin_app_proxy_1 …
Nov 04 21:42:25 umbrel umbrel startup[1808]: Creating bitcoin_bitcoind_1 …
Nov 04 21:42:35 umbrel umbrel startup[1808]: Creating bitcoin_tor_1 … done
Nov 04 21:42:37 umbrel umbrel startup[1808]: Creating bitcoin_bitcoind_1 … done
Nov 04 21:42:37 umbrel umbrel startup[1808]: Creating bitcoin_server_1 …
Nov 04 21:42:39 umbrel umbrel startup[1808]: Creating bitcoin_i2pd_daemon_1 … done
Nov 04 21:42:39 umbrel umbrel startup[1808]: Creating bitcoin_app_proxy_1 … done
Nov 04 21:42:52 umbrel umbrel startup[1808]: Creating bitcoin_server_1 … done
Nov 04 21:42:52 umbrel umbrel startup[1808]: Umbrel is now accessible at
Nov 04 21:42:52 umbrel umbrel startup[1808]: http://umbrel.local
Nov 04 21:42:52 umbrel umbrel startup[1808]: http://192.168.100.6
Nov 04 21:42:52 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Nov 04 21:17:06 umbrel external storage mounter[486]: Rebinding USB drivers…
Nov 04 21:17:07 umbrel external storage mounter[486]: Checking USB devices are back…
Nov 04 21:17:07 umbrel external storage mounter[486]: Waiting for USB devices…
Nov 04 21:17:08 umbrel external storage mounter[486]: Waiting for USB devices…
Nov 04 21:17:09 umbrel external storage mounter[486]: Waiting for USB devices…
Nov 04 21:17:10 umbrel external storage mounter[486]: Checking if the device is ext4…
Nov 04 21:17:10 umbrel external storage mounter[486]: Yes, it is ext4
Nov 04 21:17:10 umbrel external storage mounter[486]: Checking filesystem for corruption…
Nov 04 21:17:10 umbrel external storage mounter[486]: e2fsck 1.44.5 (15-Dec-2018)
Nov 04 21:17:10 umbrel external storage mounter[486]: umbrel: recovering journal
Nov 04 21:41:38 umbrel external storage mounter[486]: Setting free inodes count to 60903834 (was 60910702)
Nov 04 21:41:38 umbrel external storage mounter[486]: Setting free blocks count to 164981911 (was 193649098)
Nov 04 21:41:38 umbrel external storage mounter[486]: umbrel: clean, 151142/61054976 files, 79208297/244190208 blocks
Nov 04 21:41:38 umbrel external storage mounter[486]: Mounting partition…
Nov 04 21:41:38 umbrel external storage mounter[486]: Checking if device contains an Umbrel install…
Nov 04 21:41:39 umbrel external storage mounter[486]: Yes, it contains an Umbrel install
Nov 04 21:41:39 umbrel external storage mounter[486]: Bind mounting external storage over local Umbrel installation…
Nov 04 21:41:39 umbrel external storage mounter[486]: Bind mounting external storage over local Docker data dir…
Nov 04 21:41:39 umbrel external storage mounter[486]: Bind mounting external storage to /swap
Nov 04 21:41:39 umbrel external storage mounter[486]: Bind mounting SD card root at /sd-card…
Nov 04 21:41:39 umbrel external storage mounter[486]: Checking Umbrel root is now on external storage…
Nov 04 21:41:40 umbrel external storage mounter[486]: Checking /var/lib/docker is now on external storage…
Nov 04 21:41:40 umbrel external storage mounter[486]: Checking /swap is now on external storage…
Nov 04 21:41:40 umbrel external storage mounter[486]: Setting up swapfile
Nov 04 21:41:48 umbrel external storage mounter[486]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 04 21:41:48 umbrel external storage mounter[486]: no label, UUID=b8b0c503-b3fe-4068-a71d-e89417b4259f
Nov 04 21:41:48 umbrel external storage mounter[486]: Checking SD Card root is bind mounted at /sd-root…
Nov 04 21:41:48 umbrel external storage mounter[486]: Starting external drive mount monitor…
Nov 04 21:41:48 umbrel external storage mounter[486]: Mount script completed successfully!
Nov 04 21:41:48 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2019-02-14 10:11:58 UTC, end at Sat 2023-11-04 21:48:12 UTC. –
Nov 04 21:41:59 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 04 21:41:59 umbrel external storage updater[1727]: Checking if SD card Umbrel is newer than external storage…
Nov 04 21:41:59 umbrel external storage updater[1727]: No, SD version is not newer, exiting.
Nov 04 21:41:59 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
4948 bytes (4.9 kB, 4.8 KiB) copied, 0.000287386 s, 17.2 MB/s
Creating encrypted tarball…
backup/
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:00:03 --:–:-- 0
0 0 0 0 0 0 0 0 --:–:-- 0:00:04 --:–:-- 0
100 5470 0 0 100 5470 0 970 0:00:05 0:00:05 --:–:-- 970
100 5616 100 146 100 5470 22 838 0:00:06 0:00:06 --:–:-- 861
{“message”:“Successfully uploaded backup 1699099820149.tar.gz.pgp for backup ID 043ce90b3ddba548ea82a76a462d65e4def60a4267aa8070dff618753ba92b25”}
====== Backup success =======
Got signal: change-password
karen is getting triggered!
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
955 bytes copied, 0.000206683 s, 4.6 MB/s
backup/
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:00:05 --:–:-- 0
100 1617 100 146 100 1471 20 210 0:00:07 0:00:06 0:00:01 231
{“message”:“Successfully uploaded backup 1699124522401.tar.gz.pgp for backup ID 043ce90b3ddba548ea82a76a462d65e4def60a4267aa8070dff618753ba92b25”}
Got signal:
Got signal:
Got signal: debug
Debug result file generated
Got signal: debug
Docker containers
NAMES STATUS
bitcoin_server_1 Up 10 minutes
bitcoin_bitcoind_1 Up 10 minutes
bitcoin_tor_1 Up 10 minutes
bitcoin_app_proxy_1 Up 10 minutes
bitcoin_i2pd_daemon_1 Up 10 minutes
nginx Up 11 minutes
dashboard Up 11 minutes
manager Up 11 minutes
auth Up 11 minutes
tor_proxy Up 11 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Sat, 04 Nov 2023 21:53:13 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Sat, 04 Nov 2023 21:53:20 GMT] “POST /v1/system/debug HTTP/1.0” 200 17 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 04 Nov 2023 21:53:21 GMT] “GET /v1/system/debug-result HTTP/1.0” 200 23 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:21 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:22 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager |
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 04 Nov 2023 21:53:22 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:23 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Sat, 04 Nov 2023 21:53:24 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Nov 04 21:42:34.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 04 21:42:35.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 04 21:42:35.000 [notice] Bootstrapped 72% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 04 21:42:35.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Nov 04 21:42:35.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Nov 04 21:42:35.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Nov 04 21:42:36.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Nov 04 21:42:36.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Nov 04 21:42:36.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Nov 04 21:42:37.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_i2pd_daemon_1
app_proxy_1 | Validating token: 419ea9f708f7 …
bitcoind_1 | 2023-11-04T21:53:12Z UpdateTip: new best=0000000000000000002bb732c1c6bbbdf568fe7604be115f18d8b8eaa427c4b5 height=535615 version=0x20000000 log2_work=89.401095 tx=333185516 date=‘2018-08-07T12:03:01Z’ progress=0.374913 cache=34.0MiB(255785txo)
bitcoind_1 | 2023-11-04T21:53:14Z UpdateTip: new best=00000000000000000026551315acc74aeadb1cc0d63ac548efbe301f6350efa8 height=535616 version=0x20000000 log2_work=89.401140 tx=333187884 date=‘2018-08-07T12:31:00Z’ progress=0.374915 cache=34.7MiB(261520txo)
bitcoind_1 | 2023-11-04T21:53:15Z UpdateTip: new best=000000000000000000280446c653fe4796bef90fd7634e82bdc5abbab786a424 height=535617 version=0x20000000 log2_work=89.401185 tx=333190676 date=‘2018-08-07T12:34:34Z’ progress=0.374919 cache=35.3MiB(266636txo)
bitcoind_1 | 2023-11-04T21:53:18Z UpdateTip: new best=00000000000000000020ebf707f3914bc351231d9af1b85022f7f55f589ce04c height=535618 version=0x20000000 log2_work=89.401230 tx=333192207 date=‘2018-08-07T12:40:54Z’ progress=0.374920 cache=36.0MiB(272269txo)
bitcoind_1 | 2023-11-04T21:53:20Z UpdateTip: new best=000000000000000000014a1113021b3edc30c03a4555cc95b9fafe923e5274f4 height=535619 version=0x20000000 log2_work=89.401275 tx=333194061 date=‘2018-08-07T12:42:30Z’ progress=0.374922 cache=36.5MiB(276216txo)
bitcoind_1 | 2023-11-04T21:53:21Z UpdateTip: new best=0000000000000000002783b9d74aefbaca94a53b43e5cef7934816e8fa09eefb height=535620 version=0x20000000 log2_work=89.401320 tx=333196673 date=‘2018-08-07T13:00:33Z’ progress=0.374925 cache=36.9MiB(280088txo)
bitcoind_1 | 2023-11-04T21:53:23Z UpdateTip: new best=000000000000000000193b645803ec79d0497386c63094934cb16cf5d76761c2 height=535621 version=0x20000000 log2_work=89.401365 tx=333197232 date=‘2018-08-07T13:06:28Z’ progress=0.374926 cache=37.2MiB(282688txo)
bitcoind_1 | 2023-11-04T21:53:25Z UpdateTip: new best=0000000000000000001a682cfeb637fac2dd89f5c59a32517d16e10ed1ee9ec0 height=535622 version=0x20000000 log2_work=89.401410 tx=333197802 date=‘2018-08-07T13:07:00Z’ progress=0.374927 cache=37.6MiB(285495txo)
bitcoind_1 | 2023-11-04T21:53:27Z UpdateTip: new best=00000000000000000025c990cc28eef0ebf3911e63f5ef5a29ac593b35043421 height=535623 version=0x20000000 log2_work=89.401456 tx=333199550 date=‘2018-08-07T13:07:26Z’ progress=0.374929 cache=38.0MiB(289064txo)
bitcoind_1 | 2023-11-04T21:53:28Z UpdateTip: new best=0000000000000000001dc7bb7865a57c31a09374929de65600819ba714f8fa81 height=535624 version=0x20000000 log2_work=89.401501 tx=333202002 date=‘2018-08-07T13:23:58Z’ progress=0.374931 cache=38.7MiB(294450txo)
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:22 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:22 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.2 - - [Sat, 04 Nov 2023 21:53:22 GMT] “GET /v1/bitcoind/info/sync HTTP/1.1” 200 103 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
i2pd_daemon_1 | 21:52:09@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:52:11@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:52:13@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:52:14@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:52:19@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:53:16@186/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 21:53:22@186/error - Garlic: Failed to decrypt message
tor_1 | Nov 04 21:44:48.000 [notice] Bootstrapped 61% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 04 21:44:49.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 04 21:44:49.000 [notice] Bootstrapped 72% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 04 21:44:49.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Nov 04 21:44:49.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Nov 04 21:44:50.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Nov 04 21:44:50.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Nov 04 21:44:51.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Nov 04 21:44:51.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Nov 04 21:44:51.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
==== END =====
